Moss Supercharger
G
I was waiting to hear myself. Surely there must be quite a few installed by now. They made some pretty tall claims about the power gain....
martx-5
Well, the claims are not wild at all. They're using an Eaton M62 which is the proper size for the 2.5 litre engine. Most of these kits will put out 6 psi of boost, which on any engine is good for a 40-50% increase in power...which is what they are claiming. I have an Eaton M45 on my 1.6 Miata running at 6 psi, and I got an increase from 90 rwhp to 130 rwhp. That's a 45% bump.
G
TR6BILL said:
pretty <u>tall</u> claims about the power gain....
Tall, not wild. I believe they claim 50% increase in power on an otherwise stock engine. What happens when you increase the CR, put in a cam and....
And, how does the TR engine hold up with the boost?
Good questions. Does anyone on the forum have one yet.
Tinster?
BryanC
No experience with a TR but I had one on my 1.8l Miata. I never put the car on a dyno but the stopwatch times for 0 - 60 showed a pretty big improvement. I was running about 5.5 psi boost. I also had to run a knock sensor and / or retard the timing using 93 octane gas. I would worry about what you might have to do to avoid knocking if you had raised the compression ratio but on a stock engine it probably works fairly well.
Bryan
Brosky
I'd be really concerned about putting that kind of power on a 30+ year old engine, without doing some serious overhaul work and beefing up of the bottom end.
Then....you could have a major screamer.
Good bye clutch and differential.....
crj7driver
The local British car shop has one installed on a TR250. The car is in good un-restored condition but getting a little long in the tooth. But I got to ride in it and it was very spirited. They drive it pretty hard and have had no ill effects. This was at over 5000ft so it would have even better results at lower elevations.
swift6
That is a very good point, adding extra stress to any older engine will just accelerate the wear. Which is probably covered in Moss' "limited warranty" that you have to request separately.
Just about any engine out there can take a 6-8psi boost from a supercharger as long as its in good shape. The stock bottom end of the TR6 engine is plenty strong for that amount of boost. It can actually take a lot more boost than the Moss kit offers before you have to worry about it failing. The big weakness of the stock TR6 is more RPM related (long crank and only four main bearings). Turn up the 'wick' a bit over the standard 'kits' and you venture into newer territory.
Raising compression on a supercharged car is tantamount to suicide for the engine without the sophisticated timing and engine management systems to control knock. The supercharger is already stuffing more air into the cylinder than would normally be there so the compression is already effectively increasing with the boost. And yes, a supercharged car is more sensitive to gasoline octane than a non-supercharged engine.
Big cams on forced induction engines are also detrimental to performance. Where the overlap of exhaust and intake valves being open at the same time will help a naturally aspirated engine, on a forced induction engine it sends a bunch of your boost right out the exhaust port.
The draw of a supercharger over the cam/compression/ extra carburettor routine that some of us have done (guilty /bcforum/images/%%GRAEMLIN_URL%%/blush.gif ) is the ability to have a decent and docile idle and very easy drive-ability at lower rpm and the extra power when you stab the loud pedal. /bcforum/images/%%GRAEMLIN_URL%%/driving.gif I still prefer my lumpy idle and loud bark when I succumb to the red mist and 'gently' press my volume control lever. /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
swift6
Those guys don't take it easy on the car either. They 'demonstrate' it properly. /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
ALLAN
The advertised hp is 118 at the rear wheels, an increase of 39hp over stock, that doesnt sound very impressive to me for the cost of $3500, and with shipping that comes out to almost $95 per 1-hp.-----Although It would look and sound impressive.
R
RonMacPherson
Do a "google" for supercharged Tr6's. I pulled up a number of sites a while back. Seems that several people have gotten superchargers on their cars for about 2 grand less.
Moss is Moss. Good and Bad..
YankeeTR
39 Hp for $3500.00 might be a little high BUT you can always take it off and put it on the next car or sell it.
Try that with a cam and compression...
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
60TR3A TR2/3/3A Moss Supercharger for TR3A Triumph 41
Tabcon TR4/4A Moss TR2-4A Supercharger Kits Triumph 24
swift6 Question for those running a Moss Supercharger... Triumph 10
dpcsix moss supercharger Triumph 3
G Anyone have the Moss supercharger kit? Triumph 14
G TR6 Moss TR6 Supercharger Triumph 31
Trevor Jessie New Moss Supercharger Spridgets 6
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
