Wedge SU on TR7 Float Level Engine Angle
Got the SU's mounted to the car (replacing the Strombergs) and they.
Now for tuning. I wanted set the float level. Appears to be two methods.
1-The measurement of the float with the bowl lid upside down. For that they are both nearly identical. Higher than the 1/8 or so but the same.
2- The other method, wicked I think is more accurate, is the fuel level relative to the bridge. They are WAY off. The front carb appears about right just below the bridge (not measured yet) and the rear appears to be about 3/8 or more below the bridge.The amount they are off is equal to the tilt angle of the engine. If I crank the rear end three feet in the air... perfect.
BTW- No tabs and both needle valves are at the top with no shims.
Anyone have experience with SU's with external bowls on tilted engines?
Thanks,
Dave B
Dave
Are the fuel bowls tilted? The carbs can be tilted but not the bowls. Bowls must be sitting level, if not the engine will never run very good.
Marv
The answer is sort of both. The bowls are not exactly vertical. Not exactly sure how to explain and cannot post pictures until tonight.
The engine itself is tilted. The front is higher than the rear. The bowls follow that same tilt.
The body of the carbs and the bowls are not tilted in the other plane. That is the other surface of the carb (where the filter attaches) is vertical and so are the bowls in that plane.
Make sense?
How many degrees is the front of the engine raised? I am not the most experienced guy with SUs on here but I do believe that having the carbs on a tilt like that could cause problems with the floats.
Engine angle (tilt) is probably between 6 and 10 degrees. As I said, to get the carbs level the rear end has to be elevated about 3ft.
If the bowls were built in, like strombergs this would not be an issue. But the bowl on the front carb is forward and the aft carb bowl is aft.
So with the front carb bowl being higher, the fuel is higher in the carb, with the aft carb bowl being lower, the fuel level is lower in the rear carb. I can't find anything that speaks to this in the tech manuals etc or anywhere else on the web.
Does seem to be an issue to me. But would love to get some advice on how to address.
Put big wheels in the back. Seriously though I might consider filing the mounting bolt holes enough that you could rotate the carbs the six to ten degrees towards the front that it would take to make them level. Its a pretty low tech solution but one that should be effective.
Interesting thought. The filing not the big wheels. Although, I am in Alabama so a lift kit and gun rack... never mind.
I already fad to file the linkage to make these carbs fit. I really hope there is another solution as that does seem a little radical and I can't believe they did that to all the TR7's with SUs (Cars not exported to the USA.)
Thanks,
The big problem with my solution would be that by making them level to the ground they will no longer be perfectly inline with each other, meaning you'd have to fab a new linkage to make them work in sync.
My first thought was that they would be ok because the linkage would rotate with the angle change. But unfortunately the linkage is of course mounted to the manifold so the linkage mounting would have to rotate as well. Yea, starting to create a bunch of work. That can't be right...
Its been awhile since I worked on a 7 but I don't seem to remember the front of the engine being higher than the rear. Could you say be missing the rubber between the transmission and its rear mount?
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 4
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
bcbennett Wedge TR7 FASD vs. Manual Triumph 0
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
K Wedge TR7 Project Triumph 10
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
L Wedge TR7 gasoline odour Triumph 5
