steering trouble
dvmmatt
Member
Hi, I have a '59 bugeye sprite. last Friday it developed some "play" in the steering. I continued to drive the car and the problem seemed to go away but the steering was off center.
No more play in the steering until today. As I was getting ready to turn into my garage my steering failed! I was able to pull back on the steering wheel and get the car to turn. I'm thinking this is a worn out steering shaft?
Any Ideas? I will take it apart this weekend hopefully and see what the problem is.
Thanks for any input.
Matt
It really sounds like the spline between the steering column and the steering rack is loose/stripped.
Down at the rack area you should see a bolt and nut clamping on the rack spline but I will bet that yours doesn't have this bolt installed or if it is there then it is very loose.
BillM
Sounds like the connection between the steering shaft and the steering rack. The pinch bolt may way worked loose and allowed the splines to slip.
Sounds like the bolt is messed up and the splines are gone.
Can you have someone turn the wheel and see if that is the location where the motion is not transmitted?
BillM
If the shaft is turning the input shaft of the rack, then there is a problem with your pinion gear.
Replace the pinion gear. It's cheap on a BE rack. Also you need a new pinch bolt and a locking metal nut.
DO Not Try to Drive This Car!
I would replace both the rack and the shaft. No room for error on steering, beit yours or a failed part.
The pinion gear is easy to change out. The bolt for the steering rack must be removed completely before the column can be pulled out. You'll find the column threads to be full of rust and other road debris. Clean out the rust and other crap in there so the pinch bolt is able to be tightened. 2 maybe 3 bolts are all it takes to pop off the cover of the rack to replace the pinion gear as I recall. Well maybe more things to do but it was simple for me when I changed out the pinion gear 10 years ago on Bugsy. Likely the pinion gear threads where it attaches to the steering column are full of rust and crap as well and now likely stripped. Hence the replacement pinion gear.Make sure the pinch bolt and metal nylock gets replaced as well. Steering column for BE's may be N/A. Take it apart and get a good look. Your life depends on this one.
Just checked and all the above appear to be correct.
Thanks Kelly, it's been 10+ years since I replaced the pinion and it really tightened up the rack. This one is like the problem we had a few months ago. Exact same issue with rust and crud that needed to be cleaned up so bolt could be properly tightened.
Thanks for in put guys. I can dig in to it over the weekend. Get it all cleaned up. like was said above, my life depends on it!
Matt
Google Electrolytic Rust Removal. Might be useful in cleaning up the Steering Shaft. A battery charger, a couple of big aligator clips, wire, a sacrificial anode, a plastic tub, and a box of Arm and Hammer Washing Soda, some water and overnight in the soup will clean it up nicely for those parts you can't reach.
M Had trouble with Prestone Power Steering Fluid? Jaguar 2
roscoe Not Broken, But It Sure Hurts (Steering Wheel Pulling Accident) Austin Healey 5
PGSberg TR6 New Steering Wheel Triumph 2
S TR6 Bent Steering Column Triumph 12
C MGB MGB steering rack MG 0
T TR6 Pothole steering damage Triumph 6
S Sticky Steering Austin Healey 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
