RickPA
Member
I want to use steering box adjuster to eliminate some play in the wheel. I found that I can adjust out almost all play by lowering the pin in the box. But I get a slight bind at a certain spot. When turning the wheel to the left I get the bind at about 8 o'clock on the first turn only. It's very easy to turn through it and as the steering wheel passes the 8 o'clock spot the bind disappears.
I know it's not ideal to have the pin rub like that but is it really doing serious damage? It sure would be nice to get the slop out of the steering.
