Sprite front swivel axle information
Michael Oritt
I'm trying to source out some parts for the Elva's front suspension which has Triumph Herald uprights and Sprite hubs. Here's my question:
How does the wheel spindle on a drum-braked Sprite attach to the swivel axle assembly--Is it tapered and does it bolt through the back?
The Moss drawing simply shows the entire assembly as one piece and I wonder if the spindles themselves are available separately.
Bugeye58
Mike, they are one piece. The competition versions are modified by having a spindle made of a higher strength alloy welded into the upright.
I've wondered about the viability of doing a Spit style with the replaceable spindle myself.
Jeff
Michael Oritt
Michael Oritt
Thanks Jeff. Seeing as how the Sprite assembly swivels on a kingpin I was afraid that was going to be the answer.
The spindle on the Herald starts at the correct diameter (1") but has too fast a taper for the Sprite hub--I could probably get a machine shop to turn some for me. Any thoughts on the correct grade of steel to be used?
Bugeye58
Mike, I think the alloy used is just regular 4130. You may want to check with either Huffaker or Winners Circle to verify.
Jeff
Billm
If you are going to do any really heavy-duty driving with these then 4340M is really great and only about 10% more expensive (for the raw stock material). We (Boeing) use it on the landing gear and it is substantially better than common 4340.
Bill
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
I Wanted Sprite front brake parts Spridgets Classified 1
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
M Looking for this rare front for a Bugeye Sprite Spridgets 9
B Slot locations for Sprite front emblem Spridgets 2
T My buddy Rocco in my 64 Sprite [with bugeye front] Spridgets 2
B front disc brakes- 66 sprite Spridgets 8
djk Proper length for sprite front shock arm Spridgets 17
RickB What is this: '63 - 70 FiberGlass Front Sprite/MG' Spridgets 7
regularman Has anybody ever put a square sprite front end on Spridgets 11
HAN8L1965 Need Right Front Fender 65 Sprite Central Ohio Spridgets 5
M Front Park Turn Lamps 66 Sprite Spridgets 7
HAN8L1965 Removing Front Springs 65 Sprite Spridgets 1
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
