eejay56
Can somebody confirm my research? The engine that I pulled out of Piece O Spit is FK1074HE. From what I can tell this is a high comp 1300 from an early Mark IV. Are there any external differences between a 1500 and a 1300? It had the later electronic dizzy and ZS carb but came with a set of SU HS2s. No holes in the head for the air rails. It has dished pistons and no recess around the cylinders. If this is a 1300 can I use a 1500 head on it and flat top 1500 cylinders? What would the CR be for a 1300 HE?
