For Sale Speedo Cables Supra / Tr
mctriumph
I still have a good supply of BRAND NEW cables made exclusively for the Supra transmission swap. Factory installed ends last much better
than modified cables. Can You afford to NOT get a spare??
25$ plus shipping
Yes the w58 toyota is what these fit. 30$ includes freight
send a PM for details
Mad dog
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
GBRandy Wedge TR8 Speedo cables Triumph 5
M Lubing Tach and Speedo Cables Triumph 3
mmcglynn264 Spitfire Speedometer, differential and speedo gear issues Triumph 9
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 4
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
4tecdog Speedo drive gear Spridgets 15
N Speedo identification? Other British Cars 4
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
trotti Speedo ignition light Austin Healey 12
B Speedo needle Austin Healey 3
Rut MGB OD install, speedo drive gear MG 0
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
6TTR3A TR2/3/3A Speedo in KPH Triumph 21
Gerry M TR6 Speedo Angle Drive Triumph 2
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
E TR4/4A Speedo v Tach cable Triumph 2
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
Gerry M TR6 Speedo Angle Drive Triumph 9
F Speedo problem BT7 - cable rotates but speedo does not Austin Healey 25
