    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Lubing Tach and Speedo Cables
MikeH
Hi, Looking for opinions on what lube to use for tach and speedo cables. Thanks, Mike
I just did mine, first used oil, turned out to be too thin, caused the speedo to be jumpy. Pulled the cable and liberaly applied white lithium teflon grease,much thicker and now speedo is happy.
I have always used graphite though the speedo shop I got a cable from said to use grease.
I would definitely avoid thin oil lest it work its way into the speedo head where too much lube is worse than too little.
I take the core out of the sheath and clean both to remove any crud and to inspect the wires that make up the core. If they look reasonable, I wipe the core with a layer of Moly grease (CV joint type) and put the core back in followed by a "little" bit of gear oil (85/90 W). Like George said, you don't want lube forcing its way up into the speedo so a little goes a long way.
BTW, if you can remove the sheath from the car for inspection, that's a good idea too. Cracks and/or chips in the vinyl coating can let water in with obvious bad results. As a minimum, degrease the damaged areas and wrap them with tape. Alternatively, the home centers will have a product called either liquid vinyl or liquid electrical tape that can be applied to the cleaned sheath to provide a patch/cover.
B TR2/3/3A What do you do lubing polyurethane bushings? Triumph 7
S TR2/3/3A Lubing the water pump on a tr3 Triumph 1
T lubing trans input shaft splines; torquing pressur Spridgets 2
G Lubing a hidden Alemite Triumph 6
Cain Lubing Outer Tie-Rod Joint/Upper Ball Joint Triumph 5
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
