Speedo ignition light
trotti
Rob Glasgow
Not sure about the 100-6, but after some research I determine the early 3000 came with red plastic inserts on both the ignition and high beam indicator lights. I think later, maybe BJ7 or 8, the high beam inserts were blue.
Rob Glasgow
On most Healeys I've seen, the colored disk is missing on both the tach and speedometer. Over time either the disk shrinks or the glue holding it in the bezel dries out and the disk falls out and into the bottom of the canister. I'm not sure which.
When working on several old instruments, I've found the bezel empty but the plastic disk was loose in the canister.
Keoke
:iagree: With ROB, over time I have had to reattach the little red plastic covers over the lamps in these instruments.
British_Recovery
Bronze
Good replacement lens - red soft plastic lid from a coffee can or the like. Use a leather hole punch tool and try a few sizes. Very slightly oversize squeezes in.
Bob
trotti
trotti
Bob
Bob - thanks for the note - great idea. Right now my speedo wags back and forth at about 20 mph max with spurts to the end when it gets onry. I'm thinking of opening up and checking it out, might pick up a coffee lid and get that red amber glow again.
John Turney
.... Right now my speedo wags back and forth at about 20 mph max with spurts to the end when it gets onry. I'm thinking of opening up and checking it out, might pick up a coffee lid and get that red amber glow again.
It's more likely a kink in the cable than in the speedo.
Rob Glasgow
John, about the only way to know if original is to have been the original owner. Other than that, it's hard to know.
bob hughes
I own a BJ7 and wondered about the plastic lenses as I do not have any.
On the subject of a waggling speedo, almost definitely the cable is at fault. Changed both speedo and rev counter cables on my old girl and they work perfectly now.
:cheers:
Bob
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
4tecdog Speedo drive gear Spridgets 15
N Speedo identification? Other British Cars 4
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
B Speedo needle Austin Healey 3
Rut MGB OD install, speedo drive gear MG 0
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
6TTR3A TR2/3/3A Speedo in KPH Triumph 21
Gerry M TR6 Speedo Angle Drive Triumph 2
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
E TR4/4A Speedo v Tach cable Triumph 2
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
Gerry M TR6 Speedo Angle Drive Triumph 9
F Speedo problem BT7 - cable rotates but speedo does not Austin Healey 25
Gerry M TR6 Speedo stopped working Triumph 6
M TR2/3/3A TR3 Speedo cable Triumph 4
M Speedo pinion on Overdrive Austin Healey 1
G MGB Tach and speedo rebuild. MG 3
