TR4/4A Silly Distributor Mounting Question
ghawk16
Been a loooong while since I took my distributor out of my pedestal (think 2002) so the pictures I have aren't very clear. Can someone confirm that the clamp that goes around the distributor shaft does NOT sit flush with the pedestal? If I put the clamp on the distributor and then slide the distributor (freshly rebuilt by Advanced Distributors...great to deal with!) down the pedestal there is roughly a 1/4" gap. I would then put the two lock washers on with nuts and lightly tighten them, correct? I'm actually more worried about the gap between clamp and pedestal. Thanks
If it's anything like a TR6 the clamp must be flat with no gap. Do not force it or use nuts to draw it down...Something is mis aligned.
Again..this is based on the similarity with a TR6, so hold off until a TR4 guy pops up.
Same way, flush. Take the clamp off, remove bolt. Cafefully with a large screwdriver open the slot ( between where bolt slides thru). Then check to see that it fits around the distr groove. With it still inplace, fit it to the engine. You will have to spin it around to match up.
Marv
Marvin,
Maybe I'm using the wrong part names in the first post, but my clamp fits flush on to the distributor no problem. It's when I insert the distributor into the block and I've lined up the hole and slots of the distributor shaft to the cam/oil pump shaft. The clamp that goes around the pedestal does not sit flush to the pedestal piece that has the speedometer connection and the two studs with nuts that hold down the distributor along with clamp.
Marv
This may be silly, but the pin that drives the oil pump is not centered on the shaft. It must be on the radiator side of center to fit. Then drop it down until the dist has its proper place. By the way, shims must be used to get a free fit with the oil pump.
Le T.
When the distributor was out, did you remove the pedestal for any reason ?
Yes, the engine was completely tore down, cleaned, rebuilt, etc. But what Le T. says before I didn't notice. I have my engine at TDC and the way the rotor is pointing is close to where it should be at TDC. Only thing I can think of is when I shipped my distributor for rebuild he used a different one (not my original) and the round part of the shaft is a TAD bigger than my gear? Doubtful...but possible? But can the gear be put in 180? I would think the round hole would still be in the center as well as the tabs on the bottom of the distributor that go into the gear. Going to have to take another look in a bit. Meanwhile, pictures to show how high it sits.
Shims? I tested the float of the gear with the bushing and was in spec. Then used a very thin packing washer between the pedestal and block. It game with all different sizes.
Le T.
2 things 1. Is the oil pump properly engaged with the driving shaft?
2. All I've seen have the head of the clamp bolt on the left. You show that to be the nut. The boss where the clamp goes, for me, is about the same thickness as the clamp and the clamp is just a flat stamping. Le T.
You sir sorted me out with your post above. Sure enough I turned the engine and got the pin on the radiator side and it dropped right in! Crazy I didn't even see that. Now it sits nice and flush. And per your post below I did flip the clamp as the part of the clamp is raised and/or lower than the rest. Thank you!!!
Steve This might go for silly money... Rover / Land Rover 1
D Looking to get into racing, lots of silly questions Racing 18
tri_carb_healey a silly question Austin Healey 1
J Lucas Electrical Theory and other silly bits Triumph 6
T TR4/4A Silly question on TR4A ball joint Triumph 4
M Silly Post To Everyone Triumph 5
RocknTommy Silly '75 Midget 50th Anniversary Question Spridgets 16
W Silly question Gear Box oil change/top up MG 11
jlaird Silly problem Spridgets 8
58Custom Silly question-- Where do the washer squirters go? Spridgets 14
vping T-Series Silly question on TD Grounding MG 12
T A quick silly Crypty question. Triumph 3
fabmandan More Silly Questions Spridgets 1
B Silly wheel valve tips? Spridgets 4
DrEntropy Silly *alternators*!! Other Cars 19
vping silly idle question. MG 5
frankenstang57 This is yummy,silly ebay... Triumph 20
S Silly Quesrion- Spridgets 3
jlaird Progress - Silly progress. Spridgets 4
MadRiver TR5/TR250 Really silly TR-250 Trunk seal question Triumph 12
timbn2 Another silly Noob question on British tools... Austin Healey 6
L silly question??? MG 6
SHG Silly Spare Tire Strap Question Austin Healey 45
MadRiver TR5/TR250 Silly TR250 Vent/Blower Question Triumph 1
curtis A silly question Austin Healey 23
martyc Another silly Carb Question [piston spring?!?!?!] MG 3
B Silly engine questions that i'm sure could be found in a FAQ somewhere.... MG 15
E Excel parts prices: silly money Lotus 0
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
