Shift Points for Bugsys 948 w Cooper S Head
Jim_Gruber
So I just realized that tach I'm staring at in Bugsy is a Jaeger with a Red Line that starts Yellow at 6500 and Red at 7,000 RPM going all the way to 7.500. Jaeger out of a Porsche perhaps. Gee Well I haven't pushed this 948 to Red Line I'm sure I've strayed over 6k on a regular basis. So the question becomes this is a generator driven speedo so I'm guessing it should be dead on. This engine makes power and breathes well all the way to 6500. a normal 948 redlines at 6k. I do have a CooperS Big Valve Head, HS-2's, and a not stock cam along with an LCB Header. Thoughts on how far I can safely push it? It sure likes to rev but I don't want to damage the engine.
Worked from home today. Two errands took me out in Bugsy sunny and 68 before snow over the weekend. A last gasp at Top Down Fall Driving. 70 tomorrow but it will be dark before I get home tomorrow from work. Who schedules a Team Meeting at 4:00 PM on a Friday. Not me. BTW the drive was fabulous :smile: Front Discs and Suspension Rebuild and MC Change will happen soon.
HealeyRick
I think the important part in determining a rev limit isn't at the top end of the motor but at the bottom. In other words, if you have a standard 948 crank and rods you're probably safest by sticking to the stock red line. My 948 seems pretty similar to yours and I regularly shift at 6,000 (I have 4.55 gears so that comes up pretty quick). I might hit 6500 in an autox. It's held together well.
twas_brillig
On a similar note: I had a 1980 Yamaha RD400 two stroke twin a few years back with expansion chambers, and it loved to be shifted about 1000 rpm above the red line until the pressed together crank became wider. Got the engine rebuilt and watched the red line, but out on a late fall run in the foothills keeping up with the big bore boys at 150/160 km/hr on a cold day: pistons very hot get bigger; cylinders very cold get smaller. Rear wheel momentarily locked up as the engine seized on a long sweeper but fortunately the engine broke loose again and a rode a very rattly motorcycle home, for another rebuild. Until you've talked to someone like Winner's Circle and maybe upgraded rod bolts and added bearing caps, it's probably better to stay out of the stock red zone. Doug
Jim_Gruber
Jim_Gruber
Maybe time to swap the Jaeger for a spare BE tach in the back of my garage. Well maybe not as the time I got in yesterday was likely Bugsy's last trip out thus year. Weather gets nasty and possibility of snow flurries on Sunday. Speedhut GPS Speedo and Matching Ejectronic Tach are coming. Thanks.
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
S MGB 78 MGB cannot shift into reverse MG 3
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
S TR2/3/3A Gear shift knob Triumph 8
WHT Center-Shift Bellhousing Austin Healey 10
DrEntropy Shift rod seal in an automatic? Jaguar 7
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
C For Sale Brown Ebony Shift Knob Other British Classifieds 0
TomMull TR2/3/3A shift knob Triumph 19
J BN2 Shift Lever Bushing Replacement Austin Healey 6
J TR2/3/3A such strange thread on gear shift knob Triumph 12
D 62 center shift gearbox Austin Healey 11
AUSMHLY Wooden shift knob, how to refinish Austin Healey 35
RAC68 First Gear Shift Difficuties Austin Healey 3
D 1962 center shift gearbox cover Austin Healey 7
C TR2/3/3A Rotating shift lever Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
F Austin Side shift transmission question Austin Healey 0
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
HealeyRick 2=3 Shift Spridgets 9
C TR6 Shift lever Triumph 4
J BN2 shift bushing replacement Austin Healey 5
U Shift knob reference? Restoration & Tools 11
S 1962 BT7 transmission shift rail bumber in bell housing Austin Healey 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Shift lever issue [No Healey content] Austin Healey 0
S TR4/4A Fascia support and shift rod boot Triumph 0
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
wangdango BJ8 gear shift consol restoration... Austin Healey 9
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Zitch TR4/4A Who said the TR4 round shift knobs were NLA Triumph 4
tinman58 TR5/TR250 Funny sounds from gear shift Triumph 4
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
P Sprite Shift Lever Spridgets 20
T MGB My '80 B used to shift fine MG 2
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
6 Gear Shift Lever Spridgets 3
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
