TR6 Shift lever
crvdapena
My brother, a TR4 owner, decided to take my 6 for spin. He hopped in, cranked it up, pushed in the clutch, and then, assuming the shift pattern was the same as his TR4, he pulled UP on the shift lever, intending to then push it to the right and back. Instead, when he pulled up, the shift lever pulled right out of the linkage. I have removed the shift console cover so that I can reconnect the shifter. The shift lever is splined at the bottom but I see no way, e.g., a set screw, to fasten it more firmly to the linkage. Am I missing something?
A photo would be a good idea. No, there should be no way to pull it up too far, as there is a steel cover that goes over the ball (with a hefty spring between them). The TR6 arrangement isn't identical to the TR4, but it's close. I suspect you are missing some parts.
Or maybe you have some sort of conversion transmission? A stock TR6 shift lever doesn't have anything I would describe as "splines". Hmm, unless maybe the upper part pulled out of the rubber joint to the lower part? I've never seen one broken there, I'm not sure what is inside the rubber joint.
Here's a nice photo I just found. Item 31 is a TR4 lever, Item 32 is TR6. Items 35, 36 and 37 are the cover and spring I mentioned.
And #38 is pretty important to keep the lever attached to the gearbox top cover.
Strange you should mention that; TR6 doesn't have 38. There is no hole through the ball, just slots where two guide pins (one on each side) ride to keep it lined up. Item 70 (plus locknut 71) in this drawing. (Later, it changed to a special bolt that didn't need a locknut; but some of them had a 2nd threaded section and a nut for a support brace.)
That's right I think my 4A had two shorter bolts on the edges also but things get swapped between cars and I might be confusing it with the HVDA shifter housing.
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
J BN2 Shift Lever Bushing Replacement Austin Healey 6
C TR2/3/3A Rotating shift lever Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Shift lever issue [No Healey content] Austin Healey 0
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
P Sprite Shift Lever Spridgets 20
6 Gear Shift Lever Spridgets 3
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
TomMull Post-War Other Herald shift lever Triumph 3
PatGalvin TR2/3/3A Shift Lever Question Triumph 19
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
T TR2/3/3A TR3B gear shift lever Triumph 6
brgrmyster GTG6 Gear Shift Lever Inner Ferrule? Triumph 0
PAUL161 Gear Shift Lever Thread Size? MG 28
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
Schroeders Any of you fine folks have 1275 shift lever FS? MG 2
K TR4/4A vibrating TR-4 shift lever on accelleration. Triumph 1
H TR2/3/3A TR3 Shift Lever Removal Triumph 24
d_valentino Looking for a shift lever for a BN2 Austin Healey 2
J Replacing the nylon shift lever bushing Austin Healey 8
jbowlby 1275 Ribcage Shift lever Spridgets 2
Jim_Newman Shift lever boot Jaguar 3
davidk TR6 Shift Lever Position - TR-6 Triumph 5
B shift lever threads Austin Healey 6
davidk Gear Shift Lever Vibration Triumph 4
Bruce_B Triumph Overdrive Shift Knob and Lever Triumph 9
aeronca65t MGB MGB Shift Lever Removal? MG 8
Tinkerman Gear shift lever threads Triumph 21
vping MGB Shortening a MGB shift lever MG 51
W Shift lever retainer plate Spridgets 2
jpr28056 Gear shift lever twisting Spridgets 10
A TR6 Need TR6 shift lever measurement Triumph 4
trrdster2000 Shortened my Shift lever Triumph 8
P loose shift lever Triumph 7
T Shift lever removal Triumph 29
tahoe healey shift lever removal Austin Healey 17
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
Tinkerman TR2/3/3A TR-3, Pitting on gear shift lever ball. Triumph 2
BierRunner TR6 Gear Shift Knob Challenges Triumph 4
AHS Side-Shift Gearbox Austin Healey 3
