Celtic 77
On the way to get our Jetta in for a new timing belt, I drove our B as our replacement car. Started hearing a screeching noise, and the sound of a snapping alternator belt. Obviously, we left the overheated B at this repair shop. They called this AM stating that " Found vacuum pump pulley to be seized causing belt to shred off alternator. Vehicle needs vacuum pump assembly. Next sentence, " Alternator belt shredded due to alternator pulley not being properly aligned with other pulleys in system." Installed spacers and new belt." "Advise several bolts were loose and backed out." Total? $230.00. They charged me $40.00 for the alternator belt...seriously. I told him I replaced mine for $6.00! Several discrepancies... seized air pump pulley caused Alternator belt to shred off alternator. Then next sentence says it was the alternator belt that shredded. Scammed? I don't know. The air pump belt was fine when I checked....
