Rotor Failure
MichaelJones
While driving last night, I had a brand new rotor fail...metal arm broke away from the plastic body. Poor manufacture, or did something cause the failure. Replaced with the old rotor and ran fine. Any suggestions?
Mickey Richaud
Hi, Michael -
There has been a rash of failures of rotors over the last several years. Jeff Schlemmer, at Advanced Distributors, has the cure. Check out his website, and tell him you heard it here!
:cheers:
Mickey
PKPoole TR2/3/3A Distributor Rotor Failure Triumph 3
A Ignition rotor recommendations - odd failure Austin Healey 11
Sopwith_Camel MGA rotor pointing north MG 7
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
steveg TR6 TDC - Position of rotor and wires Triumph 4
T TR2/3/3A Does your rotor wiggle Triumph 15
MY66AH Cap and Rotor Spridgets 4
W Emergency rotor fix Austin Healey 2
mrv8q TR2/3/3A TR 3A brake rotor size? Triumph 3
I TR6 rotor specifications help Triumph 8
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
Michael Oritt Rotor specification needed Austin Healey 9
J EBC GD208 Brake rotor Austin Healey 5
pkmh Distributor rotor gone bad more than once. Austin Healey 5
B Traffic indicator rotor woes Austin Healey 5
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
T TR4/4A Rotor,caliper and Pad replacement TR4 Triumph 7
RJS Fouling Ignition Rotor Triumph 7
G TR4/4A tr 4a distributor rotor Triumph 0
J New brake rotor or get the old ones turned?? Triumph 12
H brake/rotor question Austin Healey 28
T Torque setting on brake rotor Triumph 4
H rotor thickness discrepency Austin Healey 7
D TR2/3/3A TR3 brake rotor question Triumph 4
W Spitfire Spitfire Brake Rotor Removal Triumph 4
L TR2/3/3A TR3 Brake Rotor Thickness Triumph 18
W GT6 GT6 / TR6 Rotor Options Triumph 2
T Question I should know - which rotor for Toyota Triumph 9
RJS Carnbonized Rotor Triumph 8
memphis Rotor Paint Austin Healey 6
A Rotor thickness? Spridgets 7
Monark192 No Power - replaced coil, wires, rotor and cap MG 3
K TR2/3/3A Distributor Cap&Rotor:Who has the best for TR3? Triumph 6
Atrus Disc Rotor-to-backing plate interference Spridgets 13
nevets Rotor question Austin Healey 7
T TR4/4A TR4A front rotor questions Triumph 11
P Disrributor Drive and Rotor??? Spridgets 2
M XK150 Rear Brake Rotor Dimensions? Jaguar 1
19_again brake rotor replacement MG 12
newmexTR3 Spark plug / rotor condition analysis Triumph 7
T Advanced Distributo new red rotor Triumph 19
Brosky TR6 Answer to TR6 Rotor problems...and they're RED!! Triumph 18
ChrisS Distributor rotor Spridgets 5
2wrench New Rotor, Car starts, but..... Triumph 6
2wrench Can't believe I broke my rotor Triumph 12
D TR6 TR6 Rotor woes Triumph 0
boeingpilot Brake Rotor Clean Up Restoration & Tools 4
A T-Series Rotor orientation at TDC MG 2
B TR2/3/3A TR3 rotor thickness Triumph 1
