Traffic indicator rotor woes
bob hughes
Part of my recent problem with electrics was that the indicator on the steering head was not working properly, and it certainly won't now. The rotor has broken, ie. the bakerlite part that acts as a pivot and contact maker on the end of the indicator operating lever.
I do not think anyone on this side of the pond makes them as a spare part :wall: and why should they when they can clean up with a sale for a whole new unit at £200 + vat for what is really needed is a 10 pence part.
Sooooo, has any one in the rest of the world taken the big step and manufacture them as a spare?
:cheers:
Bob
Duane_Rhynard
Bob,
Contact Curt Arndt, he is is the trafficator rebuilding expert and has many spare parts. Contact him at: CNAArndt at gmail.com
Duane
'58 BN6
B
bob hughes
Duane
Thanks for the heads up but -
Are you sure that you have the correct address for Curt, my computer does not like the one that you have supplied.
:cheers:
Bob
Duane_Rhynard
Bob,
Replace the at with the @ sign without spaces, as below.
Duane
B
bob hughes
Duane,
Made the mistake of copying and pasting then altering the address to include the @ with no spaces - that failed due to " " at each end - DOH.
All done now
Thanks
Bob
B
bob hughes
Result again. :banana:
Whilst sourcing parts for the wiper motor I happened to mention the rotor, blow me down they had one yippeeeee, all systems go, saved myself a small fortune I hope. I new horn and indicator head is just short of £240 including Vat then postage on top.:greedy_dollars:
I will pursue the rotor with Curt though, a spare is always handy.
:cheers:
Bob
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
D TR2/3/3A Traffic at or and horn button not working Triumph 2
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
Steve Citroen SM in traffic Spotted 1
Steve TR2/3/3A Spotted in traffic on Saturday... Triumph 2
DrEntropy 850 Mini in traffic! Spotted 0
DrEntropy TR-6 in traffic Spotted 3
Bret My Shark ate a traffic cone yesterday.... Other Cars 17
kodanja Keeping up with Traffic Triumph 51
Nunyas Traffic ... it became a good thing this time... MG 26
tony barnhill Building BBS Traffic MG 5
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
T Faulty Indicator Repeaters Austin Healey 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
Rob Glasgow Turn Indicator Austin Healey 17
S Indicator / Horn Switch Austin Healey 10
T TR2/3/3A turn indicator bulbs Triumph 26
D TR2/3/3A center panel indicator light color Triumph 10
B Turn Signal Indicator Light Always Flashing Austin Healey 10
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
B Indicator speeding up with time Austin Healey 4
A MGA High beam indicator light not working MG 2
R TR2/3/3A Steering Hub Turn Indicator lever Triumph 7
B The little silver indicator knob Austin Healey 0
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
N MGB "Indicator lamps" MG 0
6 Indicator Lamps Spridgets 3
sim Sprite 58 turn indicator problems Spridgets 10
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
P Coolant level indicator wrong? Jaguar 4
N Turn indicator switch??? Spridgets 1
S Turn Signal Indicator Spridgets 9
Y M Series indicator lens TVR 2
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
DerekJ Indicator blinking too fast Austin Healey 13
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
Kleykamp TR2/3/3A 1961 TR3 turn indicator diagnosis? Triumph 4
T TR2/3/3A Flasher indicator dash light Triumph 3
L Bugeye dash indicator assembly pieces ? Spridgets 0
J Turn signal dash indicator lights Austin Healey 20
L Thread size, indicator head to stator tube screws Austin Healey 0
M Indicator Flaser Relay Austin Healey 13
B Indicator light modification with LED Austin Healey 14
I TR6 TR6 turn indicator Triumph 1
Scotsman Inoperative Direction Indicator Warning Light Triumph 5
