Rear Wheel Cylinder Mounting
Healey Nut
Does anyone have any tricks tips and quick ways to install rear wheel cylinders .
Im about to rip my non existent hair out trying to get those lock plates and dust shield all in the right order . :mad::mad:
Here's a note I sent to the email list a while back:
Here's the sequence of installation that caused me the least frustration:
1) LIGHTLY grease all moving/sliding parts, including the adjuster cam and spreaders and the shaft that the handbrake lever pivots on (I use wheel bearing grease)
2) Insert cylinder into its slot
3) Slide the spring plate, with hooks pointed toward the diff, into the slot on the cylinder from above as manual shows
4) Insert the handbrake lever through its slot on the backplate from the outside
5) Lift the cylinder a little with a screwdriver and slide the handbrake pivot shaft into its notches on the cylinder (the spring plate allows this)
6) Start working the flat retaining plate with the notches into the slot on the cylinder on top of the spring plate. I tapped it in; it would help if someone held the handbrake lever out in its actuated state to prevent the spring plate from retreating from the flat plate (it might be possible to squeeze them together with a large set of channellocks). Make sure the little hooks on the spring plate engage the notches on the flat plate.
7) Work the rubber boot/dust cover over the handbrake lever and around and under the retaining plates, with the beveled edge sliding under the plates (see vid).
8) Wipe off any excess grease (it doesn't go well with brake material)
Credit where due: I'm often (always) disappointed with the quality of aftermarket rubber products, but the dust covers I got from Moss are not only molded and cut perfectly, but seem to be made of a tough rubber that should actually hold up (it's almost a soft plastic).
ps. This is as much for my benefit, as I seem to have to do this job every decade or so, and have to start from scratch procedure-wise every time.
Edit: Confirm the cylinder slides easily in its slot; I have a short video showing this, but apparently the Forum doesn't allow .VID files.
I thought long and hard about which plate should be 'on top' and which should be on the bottom. Intuitively, you'd think the flat backing plate would go next to the brake backing plate, but I believe that is incorrect; the rubber boot can only go one way because the flat plat is larger than the spring plate:
Healey Nut
Healey Nut
Ok so that seems to be the problem . The retainer plate with the little hooks on goes against the brake shoe back plate and the flat plate with notches in goes on top thus leaving a little gap around the edge for the dust shield to sit around the edge of as the flat pate is slightly larger than the opening in the rubber dust shield .
Tks Bob . Will report back .
Healey Nut
Healey Nut
Tks Bob .
Everything slid together easily , no more ripping at non existent hair follicles .
The only other add would be to coat the dust seal with dish soap or a silicone lube just to make it a bit slippery so it can be easily tucked in around the edge of the brake cylinder retainer plate (notched one) 👍
S TR2/3/3A rear wheel cylinder Triumph 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
Kurtis TR4/4A Rear wheel brake cylinder replacement Triumph 1
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
J TR4/4A TR4A rear wheel cylinder source Triumph 3
RickPA BJ8 rear wheel cylinder install Austin Healey 1
trotti Pulling off the rear wheel cylinder Austin Healey 11
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
T 76 midget rear wheel cylinder Spridgets 5
B rear wheel cylinder C clip install?? ugh Spridgets 24
5 one inch rear wheel cylinder Austin Healey 1
D Rear wheel cylinder replacement question BT7 Austin Healey 6
Stinger TR4/4A TR4A Rear Brake Wheel Cylinder Dust Shields Triumph 5
R Austin healey BJ& rear wheel cylinder problem. Austin Healey 4
R BJ-7 rear wheel cylinder removal Austin Healey 4
MGretired Rear wheel cylinder retaining clip MG 9
J Rear Wheel Cylinder Removal Spridgets 3
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
60BN7 Rear Wheel Opening Austin Healey 9
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
C Spitfire rear wheel bearing Triumph 2
Martinld123 My left rear wheel is locking up Austin Healey 16
R TR2/3/3A Rear wheel cylinders for 54 TR-2 Triumph 3
S TR2/3/3A Upholstering the rear wheel arc Triumph 3
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
D BT7 rear wheel leaking Austin Healey 25
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
T TR6 grinding right rear wheel Triumph 22
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
C Rear wheel bearing or other cause? Austin Healey 18
Jim_Gruber Reinstalling Brake Hubs and Wheel Hubs in Rear. Spridgets 5
G rear wheel studs on my 1967 BJ8 Austin Healey 5
drooartz Rear wheel hub oil seal Spridgets 6
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
J TR2/3/3A Interior rear wheel arch covers question. Triumph 2
R Bugeye rear wheel advice needed Spridgets 20
Mickey Richaud MGB Leak at Rt. Rear Wheel MG 6
G TR4/4A tr4a irs left rear wheel Triumph 14
steveg Shimmed rear wheel bearings Austin Healey 13
Crankshaft TR2/3/3A Noise from rear wheel. Triumph 1
J TR6 Inverted righ rear wheel [need help] Triumph 10
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
TulsaFred What holds the rear wheel and axle on? Spridgets 6
B Rear Wheel Bearing Oil Seal Spridgets 7
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
