Progress: four wheels on again!
drooartz
I got the new shock in from the vendor on Thursday, so I set aside this morning for finishing up the front end. It feels good to have the suspension and brake work completed -- well, mostly. There's still a few little details left and of course the brake lines still need to be done. Still, it's one more thing off the list.
Adding the old brake line brackets made the difference in the bolt lengths -- they don't drag on the discs anymore. I haven't bent over the locking tabs yet, as I'm still hoping to find a set of the proper brackets. As an aside, I'm putting all these little unfinished details on a marker board in the garage so that I won't forget to do them at some point.
<span style="font-style: italic">Calipers and front springs installed</span>
As a final job for the morning I installed the front wheels. This is the first time in over a year that all four wheels have been on the car. It's a sign of some real progress. I still have the tie rod ends to do, but they're waiting in case I have to pull the steering rack in order to fit the new brake lines.
<span style="font-style: italic">Look ma, all the wheels are on!</span>
Next up is tackling the transmission and figuring out what I want to do for fuel lines and a fuel pump. I've also got to call about getting my exhaust header coated. That's Monday's job, got to keep the process going.
leecreek
Outstanding, Drew. You are rolling now.....
jlaird
The rack does not need pulled to install brake lines hard or soft.
Whitephrog
I had to pull my rack in order to install the driver side brake line.
drooartz
drooartz
That's the line I'm thinking about, Ray. I left the rack in place while I tried to bend a new line for that run, and that's the line I wound up breaking. I'm thinking that pulling the rack will greatly simplify this.
ralph_s
Drew,
I'm light years behind you and am just in the strip down/collecting parts phase. Can't tell from the photo's did you paint or powder coat components. I'm most likely going to paint and would appreciate any tips/hints for prep and finish.
Also what did you finalize on for brake line tubing ...Moss or other.
Thanks
drooartz
drooartz
I used paint (either Rustoleum or high temp engine paint depending on the application) for the bits that I painted. I had the shocks, A-arms and kingpins rebuilt by PeterC, and they came back already finished so I'm not sure what the finish is. I don't have easy access to powder coating, so I would have used paint had I done them myself.
My painting is pretty rudimentary. I cleaned the parts by hand with acetone, a wire wheel/drill, and scotchbrite pads. A final wipe down with acetone to get rid of any grease, then I just followed the instructions on the paint cans. I painted the parts outside. They came out fine, especially since they'll be mostly unseen behind the wheels. Good enough for me.
For the hard brake and clutch lines, I've ordered a set of tubes from Classic Tube in stainless steel. They should be arriving in a couple weeks.
Bayless New Prefect progress Other British Cars 7
Bayless More Prefect Progress Other British Cars 2
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
mctriumph 61 Morgan making progress Other British Cars 3
SNClocks Progress Update Spridgets 5
SNClocks Progress Shots! Spridgets 15
prb51 AH Search in Progress Austin Healey 35
C My 2500M progress/questions thread TVR 5
D GT6 9 months later. GT6+ progress Triumph 3
J Restoration Progress - Boot Installed Austin Healey 1
F GT6 Looking to sell - in progress restoration Triumph 19
Cutrog1 How do I respond to all responses and add progress report on original article? FORUM Navigation Questions 3
Bayless More Sprite progress finally Spridgets 23
Bayless Sprite progress faster than expected. Spridgets 3
doc50 1958 Metropolitan Progress Other British Cars 4
Bayless Even more progress - the Prefect Other British Cars 5
Bayless Progress finally begins Spridgets 5
D Progress.... Spridgets 4
Rut TR4/4A Shop progress Triumph 21
Rut Shop progress Spridgets 25
Rut MGB Shop progress MG 4
69MGC MGC Wheel well restoration progress MG 4
69MGC MGC My MGC Restoration Progress MG 4
simon1966 100 Restoration Progress Austin Healey 13
Jim_Gruber Bugsy IV Progress today Spridgets 34
drooartz Making [tiny] progress Spridgets 14
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Marvin Gruber TR5/TR250 TR250 progress Triumph 15
Jim_Gruber Actually made some progress on Bugsy II Today Spridgets 4
drooartz MGB-GT Other small progress MG 3
D Bugeye Wiring Progress. Spridgets 3
Brinkerhoff T-Series TC restoration progress MG 16
RickB Knox Custom Chrome - my grille progress Spridgets 58
sim In progress 58 paint job by Premire body and paint in Visalia Ca Restoration & Tools 0
jaegzie Long time since I've been here but progress has started. Bigeye rebuild Spridgets 9
Marvin Gruber TR2/3/3A 1956 TR3 in progress Triumph 28
oxford Progress Video Austin Healey 6
2 MGA mga mk II in progress MG 2
7 Post-War Other Back to making progress Triumph 5
N Spitfire 75 Spitfire progress Triumph 6
oxford BN4 progress Austin Healey 8
drooartz MGB Finally some progress -- floors painted MG 4
drooartz MGB Making some progress with the doors MG 5
Darwin Spitfire Joy in Mudville [Spit6 progress] Triumph 1
J TR2/3/3A Need to sell my '56 TR3 restoration in progress Triumph 21
Lin Progress Up-date from Rich Berman and Andrea Austin Healey 10
Pythias 1275 transplant progress. Spridgets 50
64rocksprite Re-assembly progress and a wiper rack question Spridgets 8
M TR2/3/3A TR3 progress pictures Triumph 26
mcguijo Some progress at last Triumph 2
