MGB Finally some progress -- floors painted
drooartz
Finally had a chance to make some progress on my "winter" MGB projects. Yesterday was warm enough that I was able to get the floors repainted. They had a bit of surface rust here and there (the floors were replaced at some point in the past) but the biggest problem was that the paint was failing in places, coming off in big sheets. Picked up one of the POR15 starter kits and went through the process.
Had enough paint to do a single brushed coat -- it's probably a bit thin, but it'll do. May top-coat it with something else in the future, but it's way better than it was. Process was easy enough, just follow the directions.
Before:
After:
Black's not my first choice, but they don't make a white. It'll be covered with carpet anyways so I'm not too fussed. Good enough for floors at any rate. I'll give it a couple days to cure then it will be time to get the interior bits installed.
drooartz
drooartz
Checking back on the floors a few days on and I think this will work out just fine. Can't say it's pretty, but it's completely covered and the paint seems to be adhering just fine. Will protect the metal, and that's the important bit.
For future reference, you need two of the starter kits to do an MGB floor properly -- one kit only gets you one brushed on coat.
Platinum
Now just put a coat of a similar color to the rest of the car and you have protection, Drew. Looks good, BTW!
drooartz
drooartz
I'm thinking about doing that, Doc. Just need to find a white I can brush on -- trying to spray without taking the interior of the car apart is too daunting.
drooartz
drooartz
Well the floors are all done now, though they do look like they were painted with Rustoleum white and a $1 brush... because they were. :grin:
Still, it's a huge improvement over where I started, and should protect the metal nicely. As good as it needs to be, and now I can check this off the list and focus on getting the doors reassembled and the new interior panels installed.
Bayless More Sprite progress finally Spridgets 23
Bayless Progress finally begins Spridgets 5
jaegzie Finally some actual progress on the 69 Spridgets 4
T TR2/3/3A Finally made some progress on the TR3 Triumph 14
regularman Finally some progress Spridgets 3
scubabatdan Sorry been gone awhile, finally made progress... Spridgets 11
JPSmit Progress - finally Spridgets 4
regularman Finally a bit of progress Spridgets 14
7 Making progress finally Triumph 1
tomshobby finally, more progress Triumph 8
mgb4tim More progress - WOW, I finally worked on my car! MG 25
mctriumph TR2/3/3A Finally painted the 63 3b Triumph 14
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
tinman58 General TR Finally almost Triumph 7
J TR2/3/3A Finally getting started Triumph 20
Elva164 Finally did another onboard video! Racing 4
J It is driveable! Finally. Morris 8 Other British Cars 8
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
B Finally - BJ7 painted Austin Healey 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
