Okay, Cuz, a little refresher.
If all else fails, refer to page 519 in the Bentley manual.
I recommend, flat level ground, car in neutral with the parking brake on; key off, remove the distributor cap(making sure the carbon brush in the center that contacts the rotor is intact, and that there are no tracking cracks around any of the plug wire posts. Remove the rotor, give it the inspection, per the service manual(page 523) and also my earlier post.
Remove the hold down screw(s) for the condensor and point set, disconnect the primary wire that connects to these two items.
Take the new points and clean any shipping sealant residue off the contact points(just clean white paper(off of your printer) and slide between the points). Put a little distributor cam lube(most points sets come with a little plastic tube in the box). Squeeze that on the plastic cam arm, on the left side(as the shaft turns CCW it will hit the cam lube first). Don't be messy, but make sure the lube is on the cam plastic nubby from top to bottom) instal the points and condensor, making sure that no exposed terminals are contacting the distributor. Make sure the ground wire that screws onto the breaker plate is also fastened to the distributor body.
No set the points: two ways, dwell meter or feeler blade.
Turn the distributor so that a cam lobe is touching the plastic cam arm where it is fully centered with the arm.
You do this by turning the engine, if it is not already on the high spot of the cam lobe. Either a wrench on the alternator, crank the engine, or what I do, take the parking brake of, put in 2nd or 3rd gear and rock the car slightly(roll it forward or backward). THen adjust the point gap to .016 in..book says .014 to .016 of an inch. I recommend the larger setting as the points will settle in slightly with breakin wear.
Put the rotor back on, the distributor cap, making sure all the wires are intact, fire it up. Then if you have a dwell meter and want to double check, fasten one terminal to the distributor side of the coil and check dwell. Book calls for 35 plus or minus 3. I recommend setting it at 33 or so, as the break in wear will close the points slightly, which increases the dwell number.
OK?
