Procedure to change points?
startech47 said:
Dale,
What did the plugs look like prior to the 40 minute run?
How did the car perform during the 40 minute run?
Phil
Both plugs were brand new out of the box.
The car ran just great during the 40 minutes of driving.
I've not tried to start it this morning so I do
not know if it is still functional.
regards,
d
Cuz, can I ask a question?
When the needles were being turned the holder kept the needle holder in place, you know the one with the little roll pin sticking out the side?
I'm wondering if somewhere it might have slipped as the needle was being turned. If so it could have torn the diaphragm. Might be worth popping the top and checking the diaphragms very closely.
Could weak spark mimic running rich? If the points were set wrong or not getting good flow, could this cause the plugs to fire poorly, not igniting the fuel thoroughly, which is about the same thing as a good firing plug being given too much fuel?? Seems like Amos may be functioning somewhat well - :smile: - again.
Ron asks a good question. Are you using the proper two piece adjustment tool, rather than just a flat blade screwdriver?
<span style="color: #990000">Yupper I am !!! And I even know how to use the tool!!
I might know zip about auto mechanics but when a master mechanic
like Banjo personally demonstrates technique, I pay attention.
d</span>
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Could weak spark mimic running rich? If the points were set wrong or not getting good flow, could this cause the plugs to fire poorly, not igniting the fuel thoroughly, which is about the same thing as a good firing plug being given too much fuel??[/QUOTE]
Well Dale, since you have the adjustment tool and appear to be somewhat on your way, have you ever established if the points were correctly gapped? I can't see how they would have changed since Ben was there, but there are many mysteries hidden under the bonnet of the Beast of the Islands........
Remember, 95% of all carb problems are electrical.
Yeah, let us know either what your dwell is, or your point gap is....Okay?
Slainte'
Remember, 95% of all carb problems are electrical. [/QUOTE]
<span style="color: #660000">Points are a nice snug, clean, flat faced, non-pitted .015
AFTER I had replaced the entire fuel delivery system, yet again,
Ben sent me that quote to ponder. I stuck in a new condenser, the car
fired up right away and I got 75 miles driven before it broke down again.
Currently operational- for now.
d</span>
Then I got a little project for you Dale.
Want you to take your voltmeter, hook it up to the ignition side of the coil, from where the voltage goes to the coil. That will be the positive lead, a good ground for the other lead, battery, a good bolt, etc..
Mount it in the car, so you may have to make "extensions" for the leads. If your voltmeter has a highest reading, great, otherwise, have your passenger keep an eye on the voltage.
Now on the 20VDC scale go for a road test. Have someone watch the voltage reading. We are looking for a "spike" or "twitching" of the voltmeter needle. I am just wondering if you aren't getting a voltage spike that is eating the condensor up, possible a failure internal in the alternator, daytime first thing to go would be the ignition system. Or if you have a motor running(fan motor, etc.) you might hear its speed change. At night you would see lights "flare" up.
I know this is a far reach, but the symptoms and components you've replaced also are a stretch, so.......?
Thanks Ron,
I'll rig that up next week when I'm back on-island.
Leaving Thursday for St Croix.
d
Ah, St. Croix...............for some rest and relaxation?
However, in the Crypt............The Beast will once again have time to rest and gain it's strength back in anticipation of the Persistent One's return.
The saga continues............
<span style="color: #660000">Nope!
A young couple is house sitting for us.
They instructions to open the garage door twice
a day and GLARE at Crypty while holding jack stands.
d</span>
nevets oil filter change procedure Austin Healey 22
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
S Fuel gauge calibration procedure Austin Healey 18
S Testing and Adjusting procedure for RB340 Austin Healey 4
J TR2/3/3A Inner sill replacement procedure ? Triumph 5
S TR4/4A procedure for installing gauges etc Triumph 0
steveg Break In procedure Austin Healey 5
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
S Procedure for setting and tuning HD8s? Austin Healey 10
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
af3683 TR2/3/3A Correct Procedure to Raise TR3 Soft Top Triumph 7
R degreeing cam spec question and procedure Spridgets 23
Gliderman8 Is there a start-up procedure? ..... Triumph 10
M TR4/4A tr4A timing chain procedure? Triumph 9
R compression test procedure on 1500 midget Spridgets 5
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
R Procedure to store engine Triumph 6
T Coil Test procedure ? Triumph 10
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
J Engine Break In Procedure? Spridgets 12
T Engine bay painting procedure? Triumph 6
T Engine bay painting procedure? Triumph 0
D Torquing Procedure Racing 16
R_Lyle Replacing clutch / flywheel procedure Triumph 12
G Is there a procedure to remove the smog equipment? Spridgets 1
S Rebuilt Engine Breakin Procedure Austin Healey 4
nevets procedure for replacing brake fluid Austin Healey 14
Webb Sledge Engine Break In Procedure Triumph 9
Alfasudcrazy Starting procedure for 1975 Daimler 4.2 Jaguar 4
W What is the proper procedure for priming S.U.175's Triumph 4
S Proper Starting Procedure After Winter Storage Triumph 12
D Overdrive Stops Working After Oil Change Austin Healey 26
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
Gliderman8 TR6 Would you change oil? Triumph 5
L The Exchange Rate Austin Healey 4
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
DrEntropy Elan engine exchange Lotus 2
D TR2/3/3A Why it is important to change brake fluid Triumph 4
C MGA Change a pull starter to a push button system MG 6
F TR6 Idle change when brake is pressed Triumph 4
TRMark TR4/4A Adapting to Change Triumph 8
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
T BJ8 Fan Belt Change Austin Healey 7
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
Michael Oritt How to change signature Austin Healey 2
R BJ8 Windscreen Change Austin Healey 2
PAUL161 why the change? FORUM Navigation Questions 5
M TR2/3/3A Engine change tooling Triumph 2
