Polishing and Porting a 1500 engine
billspit
I am doing a minor porting job on my 1500 Spitfire cylinder head before it goes to the machine shop for new guides and valves and skimming. I have the competition manual that is for the MK1 through MKIV. They show how to alter the shape of the combustion chamber on the Mk I by angling down a side of the chamber. They show nothing in regards to the MK IV head, which is almost the same as my 1500, but different from the MkI. So, does anybody have the 1500 manual and does it show any grinding inside the combustion chamber of the head.
Thanks
DougF
Are you referring to Kas's competition manual? Not being a Spitter, I don't know what is available. But I have that manual if it is any help.
B
billspit
Yes this is Kas's comp manual that was done years ago, not any of his new stuff. Pretty much too late anyway. The head is going to the shop today.
aeronca65t
Smoothing the ports will help, but be really sure that manifold bores matches the cylinder head ports as well as possible....that's really more important and easier to fix.
And if you are still using the single carb manifold, you would do well to replace it with the twin carb setup...that's a HUGE boost
(I think I could make something better than the stock single carb manifold with plumbing parts from Home Depot) :jester:
You can take 0.110" off a stock head with no issues (really, more), but you may need to run high test fuel.
One thing to keep in mind about the 1500: as you improve intake flow, this really helps in the high end RPM. But the 1500 is a very long stoke engine and will not survive very high RPMs for long (I limit my 1500 racer to 5800 RPM).
B
billspit
aeronca
I pretty much did what you suggested, matched the ports and removed any obvious casting flash. I did try to smooth out the exhaust, but its pretty narrow and hard to get the finer polishing pads inside.
I have a European intake twincarb and exhaust. I have to find a down pipe though. I've heard about the sealing problems with this exhaust and may spring for a proper 4-2-1 header instead and sell my manifold on ebay. I have two 4 into 1 headers I acquired years ago, but I think they are for earlier engines.
This is going to be a street engine and no high revs.
Paul Slice
Hello Bill,
hope everything is going fine with you.
Is the engine you are building going into the red Spit that you got from me?
If so, would you please show some pictures of your progress on the car, if you have had time to work on it.
Sounds like it is going to be a strong running motor.
good luck,
Paul
vettedog72
Bull
Ask you machine shop if they are aware of a new (?) process for polishing ports where by an abrasive paste is flowed through the ports with a polished results. There are differing opinions of "polish"; some applications of some motors benefit from both intake and exhuast high polish where the TR's, from what I read do better with smothed intake and polished exhuast. Which way are you going with the Spit?
B
billspit
Paul Slice said:
Hello Bill,
good luck,
Paul
Yes Paul this is that car. I worked on the car body until cold weather set in last fall. I pulled the engine and have been diddling with it since then. The block is done and waiting for the cyl head. This has been the slowest engine build I've ever done. I had an old differential rebuilt with a new 3.63 ring and pinion to put into the car. Then my 3.89 in my MK I went out, so I slapped the 3.63 into that car. It it too high for 1147cc of screaming fury. I will likely put it into your car once the engine is done. Then I will be on the lookout for another 3.89 for the Mk I.
I worked on the only dent that is on the car yesterday. Did pretty good, but some of the dent cannot be reached from inside with the tools I have. I'm probably going to be repainting it the original color, even if it is almost a Gamecock color. I really would like a dark BRG color, but don't want the fight repainting the inside. I continue to be amazed how rust free the car was.
I can send you some pics of the engine. Pictures of the car won't impress you because it doesn't look as good as when I got it from you.
B
billspit
vettedog72 said:
Bull
This is going to be a street car with a little autocrossing thrown in if available. I don't want the intake polished as it is not a race car. I am aware of the process you are referring to and have seen it marketed by extrude hone.
I am a tiny bit disappointed by my visit to the head shop. They have no clue to the spec of a Spitfire and said they don't have books that have it. They do have Serdi machine, but weren't going to use it until I mentioned it. They also could not tell me how much I needed to cut the ehad to get to the CR I wanted. This shop was recommended by Hap Waldrop, so I'm keeping my fingers crossed.
Well the head shop just called. Seems I sent all exhaust valves. However, seems they do have reference material.
Basil Polishing and Porting? Triumph 8
7 polishing headlights Restoration & Tools 5
NutmegCT "French polishing" lacquered wood? Restoration & Tools 9
tkstruck01 Polishing engine parts? Restoration & Tools 11
C refinishing/polishing 100-6 grill parts Austin Healey 2
AH67 Polishing Foggy side curtains on BT7 Austin Healey 13
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
maxwedge5281 diy side curtain polishing Austin Healey 8
bighealeysource Best way to remove dried polishing compound Austin Healey 10
Rut Windshield polishing Spridgets 10
R Lens Cleaning/Polishing Triumph 5
bighealeysource polishing out minor scratches Austin Healey 26
wangdango BJ8 grill polishing? Austin Healey 12
glemon Polishing Aliminum Triumph 18
P POLISHING HEATER BLOWER HOUSING Spridgets 7
Geo Hahn Equipment & Product for Polishing Paint Triumph 39
60Bugeye Polishing Cockpit Surround and Window Pillars Spridgets 41
W Question on polishing up old paint Restoration & Tools 3
bigjones Polishing rubber bumpers Spridgets 20
bighealeysource waxing/polishing chrome wire wheels Austin Healey 11
Tabcon Polishing Aluminum Triumph 20
Don_R polishing carbs Triumph 25
J front grill polishing Austin Healey 12
Lin Polishing and Waxing Austin Healey 14
10musketeer Polishing Window Trim Spridgets 9
J Polishing Balls Austin Healey 11
regularman Whew, been polishing and buffing all day Spridgets 15
G Polishing my piston tops..... Triumph 5
G Cleaning and polishing up alloy wheels Restoration & Tools 5
JamesWilson Plastic Lenses- Cleaning & Polishing Restoration & Tools 10
bluemiata90 polishing chrome wire wheels Triumph 8
jlaird Polishing carb dash pots Spridgets 10
CinneaghTR Polishing/Cleaning Chrome Wire Wheels? Restoration & Tools 5
J Perspex polishing and cleaning? Triumph 6
Newkie Polishing Aluminum Wheels MG 17
bighealeysource Shut face finisher polishing ? Austin Healey 8
R6MGS Polishing plastic headlamps Restoration & Tools 12
Tinkerman Polishing dash light plastic. Triumph 7
jlaird Progress on windsheld polishing Spridgets 16
vping Be careful polishing your carbs MG 4
M XKE Engine Polishing Jaguar 2
T Glass polishing Triumph 5
jlaird Micro polishing Spridgets 8
J chome valve cover-- polishing? Triumph 6
M Piston Polishing Triumph 4
M Polishing Glass Triumph 7
R Cleaning/Polishing windshield side posts MG 2
tahoe healey stainless polishing Austin Healey 6
G New Paint Polishing Restoration & Tools 13
H Polishing an Original Healey Restoration & Tools 2
