• NOTICE: This "Forum Navigation Questions" forum is only for asking questions related to navigating this web site. DO NOT post car-related questions here., For car-related questions, use the appropriate marque-related forum.
PDF attachment help
dezand
Basil.
I created a Lucas horn rebuild summary in Word and then saved to pdf.
It is 528Kb in size which is too big to post.
How does someone add a file like this to the forum.
I never had a problem on the e46fanatics forum!
Thanks,
Nick
Administrator
Boss
Nick,
You should be able to upload a .pdf file up to 1 Meg in file size. This pdf I'm attaching is bigger than the one your are trying to upload. I'm wondering if you are trying to upload the file in a forum that doesn't allow attachments? What forum are you trying to upload
Also, to upload a file that is not a picture, you need to go to the "Advanced" editor (button for advanced editor is in he lower-right of the regular edit window). In the "advanced" editor, click on the "attachment" icon (looks like a paper clip).
  • Duplicate Finder Manual.pdf
Tr3aguy TR2/3/3A Pdf Manuals TR3 Triumph 4
K TR2/3/3A Paging TR3driver re blocked bypass and Shaller pdf Triumph 1
GBRandy Wedge TR8 Manual - PDF? Triumph 20
G Spitfire Anyone have the BL Spit prep manual in PDF? Triumph 7
L Special Tuning PDF Spridgets 4
JPSmit PDF Download Spridgets 3
JPSmit Computer Question - creating PDF's Spridgets 3
msoylemez ashley hinton pdf Spridgets 13
J TECHNICAL INFO IN PDF Jaguar 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
D BT7 Grille Attachment Austin Healey 11
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
RAC68 Harness Layout and attachment to a BJ7 Austin Healey 5
K TR2/3/3A Rear brake wheel cylinder attachment again Triumph 1
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
L TR2/3/3A Scuttle / front fender attachment Triumph 9
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
C MGB Attachment points MG 4
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
JFS TR2/3/3A Engine Removal Attachment Points Triumph 8
Rut TR4/4A Header seal attachment Triumph 0
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
D TR2/3/3A Cage nuts, attachment Triumph 6
B TR2/3/3A Rear Spring front attachment bolt Triumph 23
D TR4/4A extra long oil filter attachment stud Triumph 9
D TR2/3/3A Driving lights / badge bar attachment. Triumph 4
Tinkerman TR2/3/3A 1960 TR 3A Rear Wing Attachment Triumph 13
charleyf TR2/3/3A Commission plate attachment Triumph 21
C TR4/4A Top attachment to A-post Triumph 3
Jim_Gruber Temp sensor wire spring re attachment to probe Spridgets 3
C Top attachment under side flaps - BJ8 Austin Healey 5
B TR2/3/3A choke cable attachment Triumph 14
M Screws vs bolts for pedal box attachment to body Spridgets 6
DornTRoriginal TR2/3/3A Rear Suspension Front Spring Attachment Pin Problem Triumph 5
angelfj1 TR2/3/3A TR3A - front hood attachment snaps Triumph 10
G TR2/3/3A Re: TR3A Centre Windscreen Attachment Bracket Triumph 3
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
L BJ8 back seat attachment [new to big healeys but well versed in Bugeye] Austin Healey 2
M TR4/4A TR4A muffler hanger to cross member attachment Triumph 13
K TR2/3/3A TR3 radiator L bracket attachment to Rad? Triumph 2
Q TR2/3/3A TR3A Centre Windscreen Attachment Bracket Triumph 6
Rut Bugeye headlight rim attachment part Spridgets 18
A TR2/3/3A TR-3A door strap/stop attachment to body Triumph 10
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
A Bonnet [hood] prop attachment Triumph 16
