paint chip from stone inside wheel well
nevets
I got a small star shaped paint chip on my rear fender... apparently the damage was caused when a stone lodged in the tire thread flew off and struck the inner surface of the fender. Just wondering if there are shields or wheel-well liners available?
HiNevets, You can probably use some of the clear self adhesive plastic type covering materials to protect the paint.--Fwiw-Keoke
A couple of years ago, I sprayed my wheelwells with Fusor Wheelhouse Coating; a black rubbery surface that absorbs the stone's impact (my car was really making a racket just going down the average street).
It can be painted (which I did) or left black, as is.
Unfortunately, my server has been down since the First of October (when my IT guy moved), so no pictures are immediately available.
Edit: product is Fusor 805 Wheelhouse coating, and I've applied it to the over fifty (>50) BMW M Coupes/Rdstrs that I've redone the weak trunkfloor/differential brackets on. With fine tuning the application gun, I can replicate the BMW factory undercoating almost perfectly.
Hi Nevets
I used 3M Rocker Panel Spray.
Part number 05911
It's clear.
It comes in a spray can.
As written on the can:
Fine to medium texture.
Paintable Chip Resistant Coating.
The wheel wells should be the same color as the exterior color. So being a clear coating, this product address' that.
I haven't had any chipping as of yet. 3 years.
Roger
Tr4dude How does a paint chip lead to this? Triumph 13
P IRIS BLUE PAINT CHIP Spridgets 6
AUSMHLY Wheelwell anit-chip paint product Austin Healey 10
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 9
