Overdrive Throttle Switch
suissi
Hello everyone, I have a little beginner's question. We reversed the mass to minus. Do I now also have to change W1 and W2 on the Overdrive Throttle?
When I work from the circuit diagram, I always have a short circuit as soon as I screw the switch to the metal (ground on switch). What's wrong there? (Sorry for my English, thanks to Google.) LG suissi
Hi Suissi, By 'reversed the mass' I'm guessing you switched your car's polarity, likely from positive ground to negative. The O/D throttle switch is just a set of points opened and closed by a cam driven by throttle position, polarity shouldn't make a difference. Would you perhaps be referring to the O/D relay?
Thanks for the answer. Yes, we changed car's polarity. I've measured everything. Whenever I mount the OD Throotle Switch on the wall of the car and press the linkage on the dashboard, does the 10Amp fuse blow? If I don't wall mount the OD Switch (connected to ground) does everything work? Do I have to isolate the OD switch or should this work otherwise? Sorry again for my translation program :smile:
Edit:
The relay is wired as on the plan C1= fuse box; Switch; C2= OD Throttle Switch;ball switch,solenoid; W1=cable ground-; W2=Dashboard Switch;OD Throttle Switch
Have now found a different scheme that the connections W1 and W2 are swapped? Which scheme is correct?
The W1 and W2 connections that you've circled are on the overdrive relay, not the throttle switch. The overdrive relay just has four electrical connections. The throttle switch has two electrical connections and a lever arm with a rod that attaches to the throttle linkage.
The wire connected to W2 should be black and the other end should be next to the voltage regulator - attached to the firewall with some other ground wires. There are two wires connected to W2 - one goes to the throttle switch on the firewall and one goes to the overdrive on/off switch on the dash. The two wires should be white with purple tracer.
RickPA Overdrive throttle switch caused meltdown Austin Healey 2
Rob Glasgow Overdrive Throttle Switch Austin Healey 9
C Overdrive throttle switch rod connection picture Austin Healey 3
M throttle switch overdrive Austin Healey 4
C How to test overdrive throttle switch and need arm Austin Healey 13
bt7tricarb Overdrive Throttle Switch Austin Healey 22
GregW Overdrive Throttle Switch Austin Healey 17
RichB4493 Wanted TR3a overdrive dashboard switch Triumph Classifieds 0
B BN1 Overdrive Austin Healey 5
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
