General TR Old robbins top in box
Popeye
Bronze
Hi all,
I bought a Robbins top in 2008, and it has sat in the box since then. I opened it last weekend, and it “looks” great. No discoloration, windows perfectly clear, etc.
However, I understand the vinyl shrinks over time…
Should I try to install, or is it a hopeless cause?
I realize the lost expense - $450 for a replacement from Robbins. Normally a frugal guy like me tries to use old before replacing. However, there is considerable labor involved, as well as bits that are “one time use”: the various snaps and lift the dot pieces, and given the top is glued in places, there is considerable re-work.
Thoughts / experience?
I got a Robbins top a couple years ago, and, frankly, it just didn't fit well. Based on my own admittedly limited experience, I would trust an old one more than a new one.
You can check the length around the rear edge and compare it to the car. That's the only dimension that isn't adjustable in some way.
Thanks all. I’ll take the measurement; fundamentally the top looks good. If the measurement looks ok, I’ll have a go.
In terms of what’s to lose: a Saturday - worth a lot to a parent 😀!
Onward-ho!
I bought an NOS top a couple if years ago and determined that it was quite old. The vinyl looked great and at first the windows looked good, clear and such. But once I got it out and looked at the windows they had dimples all over them. I was able to get the windows replaced at a local shop. I then installed it on the car. I recommend you only try to install it after getting it very warm and on a warm day. It did fit but was tight from front to back.
Charley
Has anyone used an electric blanket for top installation? Seems a convenient way to get the top evenly warm… (not too hot!)
Thoughts?
Let the sun heat it up, then lay it on the bows, I usually start by clamping to the windshield header rail and various places working toward the back. The hot sun is your friend, you might have to pull and re-clamp a few times but give it a go! Patience is the virtue, don't try to rush. :popcorn:
I waited 4 years on my tr3 Robbins Top and the top was fine from sitting in the box. I found the Robbins Top fit very tight and a little longer over the door opening compared to other brands that I have put on over the years. From the front to the back there was zero extra room. In fact, I was amazed I got it to work. I worked from the center out then set the back with what I figured would be the minimum needed in the back and pulled things to the front as I worked it and just stayed with it until I got done on a hot day. I like the idea of a heating blanket. I watched some videos where they used steam.
steve
Basil I must be getting old - TVR forum! TVR 4
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
Mickey Richaud For Sale 2003 XK8 For Sale --- SOLD Jaguar Classifieds 5
BierRunner TR6 Removing the old Heater Control Valve Triumph 2
tr6web TR6 TR6 Manifold gasket help Triumph 1
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
mctriumph TR2/3/3A Old trick on SU's Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
K TR2/3/3A Old school battery shut off switch....... Triumph 3
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
S TR2/3/3A old 4 bolt axle set up Triumph 12
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
Carlbanan56 MGB Manifold plug MG 5
K TR2/3/3A Old school penetrating oil? Triumph 24
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
R Old History - List of USA TVR Authorized Dealers TVR 10
V MGB Replace late intake manifold angled breather with early model straight? MG 1
dougie Pistons - Old vs New Austin Healey 12
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
PAUL161 T-Series Original transmission sold MG 2
5 Sold My 1960 Bugeye Spridgets 10
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
roscoe New / old hard top Austin Healey 16
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
tr6nitjulius For Sale SOLD! 4/29/22 4 sale ZDDP Plus Triumph Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
