DeltaAir423
I was working on my spit (1980), and after I finished up with the routine stuff I had planned, I decided to tackle my inop fuel and temp gauges. Looks like the voltage stabilizer is bad, I tried cleaning the connectors and tightening the mounting screw. However when I put the speedo back in, and the ground wire on the speedo came out. Looks like it was previously repaired, and a new spade connector was intstalled however I don't see a loose mating connector anywhere. Can anyone trace this wire and ID where it's supposed to go?
