New to Austin Healey
Rexbd
I just purchased a 1960 3000 with overdrive. So, I have restored multiple old mustangs and Tbirds. So have a good mechanical set of skills. I wanted an English car but know this is a different cup of tea.
I have learned from reading to NOT back up with the OD on and am getting a feel for all the various places you have to provide oil (eg carbs). I have bought several manuals to read through. Any pointers on simply driving and enjoying the car?
I want to make it safe and dependable for now and when I retire in a year will really get after restoring the car.
I highly recommend that you join the nearest club in your area.
re: "Any pointers on simply driving and enjoying the car?"
In a way, you kinda answered your own question: Drive the car--no matter where and for how long--and you will enjoy it. I recently sold my late father's '65 Mustang convertible and '55 T-Bird and, although they were great cars they weren't the same experience. Both felt like yachts compared to my Healeys, a '56 BN2 and a '67 BJ8, and the Healeys easily 'out-handled' both of them (and, although I only got a brief ride as a passenger I felt the Healeys were much more nimble than our neighbor's original Mercedes Gull Wing roadster). The BN2 is more the pure sports roadster, and the BJ8 is more of a grand tourer, both fun in their own ways but the 6-cyl car is best on long trips for its 'legs.' Until a couple years ago me and my BFF took a long Healey trip in late spring; the latest was over 5,000 miles in about two weeks. We only put the hood (convertible top) up in the most severe weather, expected to last over an hour; we found that if we could keep speed up to 60 or more we wouldn't get terribly wet, at least after I rectified some leaks (the back 'seats' however, were a different story). It's the next best thing to being on a motorcycle, and I'd argue better because you don't have to wear a helmet, you may well be 'closer to the road' and can haul (slightly) more stuff and are arguably 'safer.' We stuffed the boot with spares and tools, and got by with a couple duffel bags in the rear seats.
Despite the 'horror stories' you may have heard about British cars, Healeys are strong and robust drivers (their success in rally races attest to it). One weak spot is the original SU fuel pumps; most have issues sooner or later, but a rare few claim they have never had one fail (routine maintenance is key, supposedly). Some have replaced the SUs with Facets or other brands, I carry at least one spare and can swap it out in 20 minutes; I like the sound of the SU pumps and I think it's part of the cache' of the cars (solid-state versions are available).
Most/all Brit cars are infamous for electrical issues, which is odd because the wiring seems, if anything, to be overbuilt, but I believe a lot of the issues are due to the ancient 'bullet-style' connectors (my dad's Model As used the same style!). Since you're doing a full resto I recommend a new wiring harness and connectors; and use dielectric grease in the connectors to occlude corrosion, which can be the source of many intermittent, frustrating 'gremlins.' Make sure to protect the wiring from any source of chafing or other damage.
Edit: Instead of dielectric grease, consider getting some of this, recommended to me by another owner. A bit expensive, but if you're rewiring the whole car it should be worth it:
Some of us have fitted PCV valves; not a true PCV 'system,' but it helps reduce crankcase pressure and the notorious leak at the rear crankshaft 'seal' (the engine doesn't have a seal, but a scroll-type oil return on the crank, which relies on close clearances which, of course, wear over time). Some fit aftermarket seal kits, but a properly installed PCV valve can limit the puddle under the car. We fitted a seal kit to the BN2 it still leaks a bit (others have had more success).
The drivetrain is very strong; the possible 'weak link' is the overdrive, which is fun to switch on and off, and takes a bit of technique. Racers break them, but they're supposedly good for up to 200HP and in routine driving should go 100K miles or more without an issue (issues are often with the electrical system). Everyone seems to use a different technique to de/activate the OD; check back when you're ready to try it out.
I don't know if a '60 had a front disk brake option but, if not you might consider an upgrade. My BN2 has drums all around, but it's a lighter car and I don't drive it hard or for long distances, but the heavier BJ8 with front disks and a servo is the better stopper.
Sounds like you're a pretty good 'wrench,' so there won't be a lot of surprises. One possible one is the SU carburettors (Brit spelling), which are different in principle from American carbs; they're 'variable choke' as opposed to 'fixed choke,' but once you understand their theory you'll find they are simpler--with a single jet and no accelerator pump--and more elegant than American-style (with multiple jets, pumps, 'power pistons,' etc.), My dad wasn't a fan of 'foreign cars,' until he bought the BN2 which we restored together, but he rebuilt its carbs to perfection (he was a good wrench, too).
Congratulations on an astute purchase! I started my Healey journey with a 1960 model and I know you will have a lot of happy miles ahead. One watch out that you've probably already encountered is speed bumps. Per a quote from an old Road and Track article, "a crush-proof box of Marlboros will rip the exhaust off the car" -- or something like that. I did notice that I could not avoid scraping the muffler over large speed bumps.
Mine had front disks which I believe were stock starting in 1960.
I thought about one additional point on the Overdrive that you may already be aware of, but just in case....
If the car is running in overdrive, and you turn the switch back to normal, you don't want it dropping out of overdrive immediately. Instead you should have to accelerate a little. This is controlled by a switch on the firewall that is coupled to the throttle linkage. I think this helps protect the overdrive unit from the same kind of damage as if you ran it in reverse. This can be adjusted if needed -- the shop manual covers it.
For me it works well -- if I'm approaching a hill for example, I turn the switch back to normal and then when I have to put in more gas to get up the hill, it also kicks down. Of course a Healey can climb most hills in 4th OD anyway, which is one of my favorite features of the vehicle -- gobs of torque.
-- Paul J.
Basil Other Austin Healey Enthusiast sites Austin Healey 0
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
dougie Austin Healey 4000 Austin Healey 3
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Editor_Reid "Austin-Healey Quarterly" e-zine Spridgets 2
Editor_Reid "Austin-Healey Quarterly" e-zine Austin Healey 8
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
T "B" designations for Austin Healey 3000s? Austin Healey 1
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
HealeyPassion Hockert's Austin-Healey on eBay auction Austin Healey 8
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
GeorgeC Rich Chrysler's "Introduction to Austin-Healey Restoration" Austin Healey 3
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
I Austin-Healey BN1 Parts List Austin Healey 4
T Shipping an Austin-Healey to Australia Austin Healey 0
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
lbcspinners New article today from Hagerty Media: the Austin-Healey Sprite Austin Healey 0
dougie Austin-Healey 100 Documentary Austin Healey 3
MikeAH100M Austin Healey Book by Geoff and Signatures Austin Healey 3
John Turney Not an Austin But a Healey Nonetheless Austin Healey 12
H 100-6 Austin-Healey Austin Healey 7
T For Sale 1961 Austin Healey BT-7 for sale Austin Healey Classifieds 1
Guido36 Austin Healey Fiberfab Banshee Austin Healey 1
red57 Wanted WTB Early Austin Healey Horns Austin Healey Classifieds 1
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Editor_Reid For Sale 1956 Austin-Healey 100M [real one] Austin Healey Classifieds 0
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey Bugeye Sprite MK 1 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
