100-6 Austin-Healey
huntlu
Hi. I bought a 100-6 Austin-Healey series BN6. The problem I have is fitting the doors. My father cut all the rotted sills and outriggers and then just welded in the new ones without addressing the sag in the frame, so I had to recut all the sills and outriggers, jack the car up in the middle, and reweld everything, but the doors still are way off. If anyone has any advice it would be gratefully appreciated. Thanks.
healeyblue
You'll have to be more specific. Are the doors too tight in the opening? Do they have too big of gaps to the fenders? Does the body lines not match the fenders?
H
huntlu
the doors are about 1/4 inch over the rear fender not enough room shut face and aluminen face.the front gap looks pretty good although door sticks out too much and hangs too low,not enough room to put rockers on.
roscoe
The chances of something being wrong about the doors themselves is unlikley. Once youve eliminated that you are left with correcting what the real issue is or doing what you can to get the gap and look you want. If it is the framework around the door being off due to frame distortion or a previous repair that was not properly fitted, you might want to correct that. That may be a tough row to hoe and it depends on how deep you want/ need to go. 1/4 " is a lot to be off but if you can save the swage line, one quick and dirty option is to cut the edges of the door to where you want them and use some welding rod to remake a rounded edge to achieve the gaps you want. The doors would never be useful on another car but that probably wouldn't be your worry. Just imagine some other owner saying " what in the world did this guy do here"?
These cars are a never ending story. I've heard of folks filling the door gaps with lead and then using a thin cutting wheel and some filing to obtain " perfect " gaps all around. If this all sounds like cheating, my philosophy is that there are few rules for doing sheet metal as long as the foundation is solid. If a soggy frame is really the problem it needs to be addressed but if it has just been tweaked you have more options.
For increasing the door gaps at the rear pillar, if small increases are all that is needed, it is possible to shave material off the hinge face where it mates to the door or front pillar. I doubt you could get anything near 1/4 inch this way but I had to use this option on one door and was happy with the result. The hinges are quite moveable up or down and in and out as long as you aren't ruining the swage line match you have some leeway there. Due to the swage contour the doors can only be in one spot to match. Doors can be a bugger.
John Turney
My guess is that you will have to undo the rewelding of the sills. With the doors still attached to the "A" (hinge) pillars, adjust the sills until the doors align, insert a brace between the "A" and "B" pillars to maintain alignment, and tack weld again. I don't envy you.
H
huntlu
Hi thanks alought for all the info you gave me alot of thins to try.the doors are from another vehicle so that could be one problem.thanks again huntlu
H
huntlu
hi thanks for the info,somebody else told me the same thing thats probably what i will try.huntlu
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
dougie Austin-Healey 100 Documentary Austin Healey 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
Z For Sale 1956 Austin Healey 100-4 race car for sale Austin Healey Classifieds 1
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P Wanted Austin Healey 100-4 Bulkheads Austin Healey Classifieds 2
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Austin Healey 100 engine color Austin Healey 10
S For Sale Austin Healey 100-4 Grille Austin Healey Classifieds 2
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
vette What is an Austin Healey 100-6 MM kit. Austin Healey 10
W Austin Healey 100-6 Sell or Restore? Austin Healey 5
L For Sale Austin Healey 100 literature for sale Austin Healey Classifieds 1
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
L Tinplate Austin Healey 100 model Austin Healey 3
pan Austin-Healey 100 BN1 Gears Austin Healey 5
F Great set of videos showing the superb resoration of a Austin Healey 100-6 - a must Austin Healey 3
AN6-TX New Book: Factory Original Austin-Healey 100-6 & 3000 Austin Healey 8
B Austin Healey 100-6 Bn4 Badge Number Austin Healey 17
C Help!!! Austin Healey 100-6 engine problem Austin Healey 2
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
E Austin healey 100 s car auction july 12 th Austin Healey 0
andrea Austin Healey 100/6 cross flow heater pipeclips Austin Healey 3
T A new Opportunity 1959 Austin Healey 100-6 Austin Healey 9
D Austin Healey 100-6 Compression Austin Healey 1
E Austin Healey 100 parts Austin Healey 5
M Mirrors '56 Austin Healey 100 4 Austin Healey 23
S Austin Healey 100 6 screw list Austin Healey 6
B Found: 1955 Austin Healey 100-4 Austin Healey 8
J Austin Healey 100 S Austin Healey 21
B Austin Healey 100-4 barn find! Austin Healey 23
Tony_Bowen Austin Healey 100-6 Stuck motor... Austin Healey 19
S Austin Healey 100 6 numbers Austin Healey 10
d_valentino Austin Healey 100 "Fitted Luggage" Austin Healey 6
d_valentino 1955 BN2 Austin Healey 100 Questions Austin Healey 39
