New member in Illinois
Bernie H
[h=2]First posted in the Austin Healey forum-My mistake[/h]
Hello, I have recently bought a bugeye and found this forum as a source for advice, and possibly sympathy. The car is in reasonable shape, some one had worked on it in the past and there appears to be a fair amount of Bondo in what I assume are the usual places.
I grew up in England and spent much of the 1970s nursing an A35 with little money for parts and few tools. I have restored a few vehicles in the last few years, Chevy trucks and Jeeps, and thought it would be interesting to try a Sprite. My children talk darkly of a second childhood.
I am in process of replacing the front drums with discs and a dual master cylinder. It is going fairly smoothly although I had to weld in a new pivot for the passenger side wishbone. From Google searches I see that I have to move the wiper motor. The flexible shaft is in some kind of tube which does not seem amenable to being moved and the shaft itself does not seem to be long enough to be moved. I think that I must be missing something so any advice would be greatly appreciated.
Bernie​
You found the best British Car Blog around. These guys have saved me a ton of times. I also need to remove the wiper drive cable and have a post next to yours. Glad to have you here.
Paul
Bernie,
Welcome to the Forum! No advice from me, but someone with that knowledge will be along shortly.
Rut
I assume you are removing the wiper motor so you can install the new pedal assembly for the dual master cylinder. The cable can be removed from the motor without too much trouble. First mark the location of the "Hat" secton on the cover plate so that the stop location will be the same after reassembly. Unscrew the nut securing the cable to the motor. Take the cover plate off and you can separate the cable from the motor. Reassembly to the reverse.
The gear and cable rides in a lot of grease. Depending on the age you may want to clean it up and replace the gerase
I have never tried to fit the dual master system but I can see how the wiper motor may in the way during installation of the new pedal box and hydraulic bits. I assume the motor goes back in the same location after the new system is in place. Although I having been living with the single line system for 50 years, I have contemplated doing the switch over the dual line. I have a friend who says that we are all crazy using the single line system when a dual is available.
Please keep us posted as to how this project goes.
If you use the single line 3/4" dual master from the early disc brake cars nothing has to move. Its a bolt in.
Further, I have had brake failures with the single line system and they never came without a warning. People lived a long time before every car was forced to go to dual line brake system's....probably longer than today!:friendly_wink:
Sprites and Midgets have excellent hand brakes and I have put in a few miles with only the hand brake in traffic and survived. Don't succumb to the namby pamby world big brother wants to get you into!:rolleye:
Kurt.
Thank you for the welcome. From searching the web it seems that I need a later model (round body ?) wiper motor which is presumably smaller. Apparently this will also give me two speed wipers. I found an explanation of the wiring, but does anyone know if I can just connect to the old drive cable ?
Moss lists the same drive cable part number for all years. The lengths vary with model though as they say the cable needs to be cut to length
Oh, you poor bastard. You're entering a world where the parts are cheap but the owners are cheaper yet. Everything is simple until it's not. Reproduction parts are readily available, but he don't fit and don't last. Lucas electrics (need I say more? You grew up in England with warm beer.) My niece asked me why the cars weren't worth more. I told her because they leak. She said "Leak what?" I said everything.. Everthing that's supposed to stay in leaks out and everything that's supposed to stay out leaks in. .. These cars aren't as bad as Fiats, that go from 99% perfect to 95% to 90% to 80% and on down just sitting there, but almost..
On the other hand, every time you drive it, and I mean EVERY TIME it will bring a smile to your face. People will stop you and ask questions or make comments about how cool it is. The people here (and on the list spridgets.autox.com) are like no other in knowledge and assistance. It really is a community. (check out stories such as the "Holy Sprite" for example). It's not just a car, it's a lifestyle... .. .. .. ...... poor bastard.
I will not get into an argument about beer. Suffice to say Budweiser. I did once own a Fiat, they started to rust on the boat coming over. Even worse is a Moskvitch ( I think that is the spelling). This is a Russian made Fiat; not a quality product.
I went with my wife to pick up the car, bought on eBay.We picked it up about a day's drive away and brought it back on an open trailer. She had reservations about the whole project, but the crowds that gathered at rest stops and gas stations worked wonders.
One of my children bought me a T shirt with the Legend " Old cars don't leak- they mark their territory"
:highly_amused:
Welcome aboard! The guys around here have saved my bacon many times over.
B New member in Illinois Austin Healey 4
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
M New Member with an HD8 Carb Question Austin Healey 1
J Member Search? FORUM Navigation Questions 4
S MGB Transmission cross member re-install MG 14
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
NutmegCT Member near Portland Maine? Other British Cars 46
NutmegCT General Tech BCF member in Maine? Triumph 0
Madflyer TR6 I am now a member of the TR Backlight cars Triumph 7
P New member TR2 carpets Triumph 7
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
NutmegCT New member tweak? FORUM Navigation Questions 0
M MGB New Member MG 1
B TR6 New [Old] Member Triumph 2
B TR6 New Member, first post Triumph 1
A Hello from new member, and car identification help request Other British Cars 9
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
G 100/6 Radiator cross member Austin Healey 6
S New Member 1967 Austin Healey 3000 Austin Healey 5
R TR2/3/3A Tie Member for TR-2 Triumph 2
S TR6 Steve new member Triumph 3
F TR2/3/3A Tie member[front apron support tube] Triumph 11
J New member Austin Healey 11
Basil Volvo and BCF member! Spotted 17
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
A TR2/3/3A New member here, Happy New Year Everyne :-] Triumph 7
J front cross member height from bottom to floor on BJ8 Austin Healey 5
D new member needing help with buying a 3000. Austin Healey 39
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
rays653000 New member and looking for some paint help Austin Healey 14
J New Member, Year of Manufacture/Title Question Austin Healey 9
Basil Lost a member - Blueghost Spridgets 9
Italia 227 Post-War Other 1961 Triumph Italia 2000 GT – new member Triumph 19
C Austin FX3D wiring diagram needed, New member here Other British Cars 3
Lukens TR2/3/3A Thanks to the forum and specifically a member. Triumph 4
A TR4/4A New member w crazy TR4a Triumph 43
R new member with a 57 Austin Healey 49
Boggsy64 MGB Front Cross member pads MG 4
pan Family member visiting Australia Austin Healey 3
PatGalvin TR5/TR250 New Family Member Triumph 15
TRspitfirefan Spitfire New member. Triumph 16
S New member saying "hello" Triumph 8
KVH How do I Access All the Albums and Member Pics FORUM Navigation Questions 1
Vineyarder BN1 BN2 Transmission Question, Returning member Austin Healey 0
AHS TR2/3/3A New member [with a TR3A project] introduction Triumph 14
oxford new member BN4 Austin Healey 11
D new member with wire wheel questions Jaguar 6
D new member with wire wheel questions Austin Healey 7
D neww member with wire wheel questions MG 11
