New 5 speed conversion for 280i guys
Grady
Member
What became of all this - do you have a running 5 speed and will it just bolt up with no fabrication, cutting, & patching? Inquiring minds still want to know!
DeltaAir423
Too bad I missed this post from earlier. I was going to tell you if you need any "new" Ford parts, one of my favorite places to go is https://www.partsgalaxy.com I can't count how many times they have saved my behind when I needed a part.
Sparkie
Sparkie
The slave cylinder is the stock annular setup on the new Mustang T5 trans. My used tranny came with it attached so I will use it!
tr7andtvr
Is it a push type or a pull type? My v8 conversion is finished but I am having to "pump" into gears. Do you have anymore info on it? Make model?
Andy
Sparkie
Sparkie
Andy,
Sorry to hear of your clutch probs. You may have an easier fix by changing the slave or master diameter. Larger on the master and/or smaller on the slave so less pedal yields more throw.
The annular slave on the Tremec is from a late model Mustang with V6, as I said, but a search of the web yielded no info on a factory stock setup. I did find an outfit that specializes on annular slaves, Dorman Clutch. Summit sells some of their stuff. They list a slave for a 2006 V6 Mustang, which would have the T5 - a late model of it; can't guarantee the bolt pattern is the same, but I would be surprised if they changed it. Or perhaps match the slave to the vehicle type that the tranny came out of.
I don't know if the stock one is a push or pull - I would assume a push but I have seen advertisements of similar looking units as both push and pull. I can tell you it mounts directly to the front snout ot the T5, just like this Dorman, with the integral throwout pointing forward and the hydrolic input toward the tranny.
I may have the same issue when I hook this up to the TVR master.... You may as well - and have to change the master even with this annular slave.
Here's a pic of the Dorman unit.
benebob
Scotty,
Do you have an update on your 4.0 conversion? I just bought a non running 280i that you have my intrest peaked about converting to a 4.0 (though I'd love to do a newer stang 4.0 SOHC and 5 speed) as they seem cheap as dirt with sub 20k on the odo. Just saw one with 200 miles for $500 complete with engine, wiring harness, computer and an auto tranny (hence why I waited.
Ben
Genos2
Thought I,d pass this along, camaro LS1 uses the similar slave setup& while I was working at a turbo shop(5 yrs) we did alot of these& GTO's& with alot of competition clutch setups they included a aluminum spacer that went behind the slave assembly(held in by the 2 mounting bolts) inorder for the clutch to disengage completely.It was 3/16-1/4 inch thick. Without it you had to pump the clutch to make it work fully.Also on these you had to follow OEM bleeding procedures. hope this helps cheers Genos2
Grady
Member
Another year later, another bump...
As I piece this long thread together:
Start with a 2005-2007 (or later) 4.0 V-6 & Tremac 5 speed
<span style="text-decoration: underline">Flywheel </span>6 bolt flywheel (Mustang or Ranger???)
<span style="text-decoration: underline">Starter</span> from a manual Mustang
<span style="text-decoration: underline">Clutch slave </span>- did the original Mustan one work?
<span style="text-decoration: underline">Drive shaft</span> Modification to the front end of the drive shaft
Did you guys ever finish this, take pictures, have a parts list??? Any help would be appreciated. Grady
birkline
After being told by several "experts" that Ford never mated the T5 trans to the V6 Cologne engine, I found this to be incorrect.
It turns out that all 2005 to present Mustangs have a base engine that's the 4.0L SOHC V6 and it's a Cologne engine!! It's a piece of crap engine (with the same small oil pump as our 2.8L), but the manual transmission is the Tremec T5!!!! There's also a 5 speed automatic available (there’s one in my town available with only 330 miles for $750).
I just checked the bellhousing bolt pattern this morning at my local dismantlers hub and it is verified - the SOHC in the Mustang is a match to the plentiful 4.0L OHV engines in most Rangers (and several other vehicles) – as well as our stock 2.8L.
My transmission with bellhousing cost $750 and had only 19K miles on it. Full speed ahead with the 4.0 swap and now it will have a bulletproof 5 speed!
When I sold my 280i coupe back last Jan, I enclosed that bellhousing in the sale.
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
roscoe 5 speed conversion question Austin Healey 9
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
M TR6 5 speed conversion Triumph 33
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
rjc157 TR6 5-speed conversion Triumph 7
E TR6 Eaglegate 5-speed conversion help Triumph 1
mctriumph For Sale 5 speed conversion kits [formerly by eaglegate] Triumph Classifieds 3
rjc157 TR6 5 speed conversion Triumph 7
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
M The value in 5 speed conversion Spridgets 18
Rut 5 speed conversion Spridgets 4
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
Keith_M 5-speed conversion or not Spridgets 57
Mickey Richaud Midget 5-Speed Conversion Spridgets 6
bugedd 5 speed conversion trans oil Spridgets 7
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
JodyFKerr Spitfire Spitfire 5-speed conversion Triumph 9
Rut 5 speed conversion wish list Spridgets 28
B Healey 5-Speed Conversion Austin Healey 27
Gliderman8 5-Speed Conversion - Shifter Triumph 10
Gliderman8 5-Speed conversion Latest Triumph 13
HealeyPassion Question for 5 speed conversion guys Austin Healey 13
jhorton3 New Project...5 Speed Conversion! Spridgets 17
M AH 100 5 Speed conversion questions Austin Healey 21
prb51 Gear ratio/speed conversion Triumph 0
healeyboz 5 speed conversion Spridgets 15
CCURTISS T-Series TF Engine Lift Points for 5 speed conversion MG 3
CCURTISS T-Series MGTF 5 Speed Conversion MG 3
64rocksprite 5 speed conversion thoughts? Spridgets 7
gsalt57tr3 5 speed conversion for the 1500cc midget Spridgets 5
J Morgan 5 speed conversion Other British Cars 8
mgbmedic MGB MGB or TR6 -- 280Z 5 Speed Conversion MG 2
Bob McElwee Toyota 5 Speed Conversion Questions Austin Healey 10
budk1953 5 Speed Conversion Question MG 6
Hap Waldrop Rivergate 5 speed conversion questions Spridgets 42
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
LeeMcKee TR6 TR6 Five Speed Conversion? Triumph 5
kyreb1862 MG 5 Speed Conversion MG 20
S 5 speed 210 conversion and shifter question? Spridgets 7
PeterK 5-speed conversion pic Triumph 17
W 5 Speed conversion gear box MG 3
S Rivergate Five Speed Conversion Spridgets 6
77_MG_Midget 5 speed tranny conversion Spridgets 9
B Rudd Speed Conversion Austin Healey 3
MGA Steve Spitfire Spitfire 1500 5-speed tranny conversion Triumph 0
