never throw old parts away....
  • Thread starter Deleted member 21878
  • Start date
i started putting in my windshield today. i ordered new glass, seals, and brackets to put it all together. i started at the bottom of the windshield and worked my way up to the top. all was going well until i went to put in the top brackets. with all the screws tight i could not get the miters to pull up tight at the top. i had about a 1/8" gap on the one side and a 1/16" gap on the other. you could see right thru.
fortunately i had saved my old brackets... and again fortunately only one screw had broken off in the top brackets taking the old windshield apart. i was able to drill out the broken screw and use the old top brackets. they pulled the top miters up tight.
while apart i compared the new and old brackets. on one side of both new top brackets the holes were about half a hole off which caused the gap. if you are going to change your glass, save your old brackets no matter how bad they look.
Thats the problem with the far eastern repro stuff , it just dont fit , work , look good etc .
I much prefer to spend more $$$ restoring the original stuff than installing the cheap repro crap thats no good and your never happy with .
I had that same problem ten years ago when I restored my car! Guess “they” continue to sell those poorly fitting parts after all this time.
Lin
Hi All,
I hate to agree but, even back in the late 1980s when I did a total dismantling and rebuild of my BJ8, many of the purchased parts from the major suppliers were returned in favor of redoing my originals. Back then, you could still find cars in the junk yards and, since I traveled quite a bit in those days, would identify the suppliers and visit the yards. Since I also intended to re-do my interior (door panels etc.) to exactly as original, I spent close to a year visiting vinyl suppliers before finding an exact grain match (seats still original).
Sorry, but I have found that you can fix or repair almost everything on the Healey and new replacement parts usually have a shorter longevity and fit difficulties. My conclusion is based upon my experiences with standard parts but have found good quality and high expense from specialty parts providers as Denis Welch and a few others.
From my own experiences,
Ray(64BJ8P1)
well i would have used my old brackets but just about every screw on the bottom ones broke in the bracket.
Yep, never throw those parts away [or let anyone else do so]. Been there done that. Experienced the anguish of the realization. :culpability: Many a time, actually. :mad-new: I also was thrilled many years ago that those exact parts were available from the usual suspects for a reasonable price. As my soft top was pulling the upper frame away from the windscreen I ponied up the dough and sent away for the pieces. Alas,,, the new ones were shiny but useless so I ended up repairing the originals. I still have the new ones in my parts stash. Though I sure wish I still had the front brackets for my BT7 hardtop. :cheers:
bring up a question:
i am about to start putting this engine back together. i took the oil pump apart and checked it for wear. there is very little play between the gears. nothing else stands out either as an issue. out the same one back in? order new gear and put back in? replace?
If the gears are not worn and sloppy and the cover plate doesnt have wear on the face I would clean it and prime it and put it back together . You can also reface the cover plate with a piece of glass and some grinding paste to smooth it out if its a bit worn .
F TR2/3/3A RULE#1 Never throw anything away Triumph 3
Jim_Gruber Never throw anything away!! Spridgets 7
drooartz Why you never throw anything away Spridgets 16
mctriumph General TR They are never DONE!! Triumph 5
mctriumph General TR NEVER start a car with stale gas Triumph 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
AngliaGT MGB-GT I Never Thought of an MG as a "Cookie Cutter" Car 'til Now MG 3
69MGC T-Series Never thought I'd switch MG 5
R General TR Emergency hot wire - because you never know whats next Triumph 2
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Gliderman8 General MG The car that never was MG 6
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
doc50 TR2/3/3A Never seen a TR3 with this feature. Triumph 2
CZ_Dave MGB Ya Just Never Know What Cha Find MG 5
drambuie You never looked so good! Austin Healey 9
mrsprite Old Spridgets never die... Spridgets 6
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Keoke SEE it is never too late Austin Healey 3
JPSmit Bring a Trailer - I never even knew this existed Spridgets 4
DNK Never Seen One of These Before Other British Cars 3
Sherlock Betcha never heard of this one... Other Cars 6
hilsideser Never seen one of these before... Spotted 5
AH67 facet fuel pump never stops ticking. Austin Healey 6
DNK Never saw that... Triumph 0
Mickey Richaud Never Seen One of These Sunbeam (Rootes) 0
bighealeysource Never been in a Concours - what do I need to do ? Austin Healey 22
G Never give up hope ! ! Triumph 2
HealeyRick Sunday Will Never be the Same Austin Healey 0
JPSmit Never seen one before Other British Cars 8
drooartz Never been so happy to have a speedo die MG 0
MCNX_BFF Triumphest 2010 pix --Better late than never? Triumph 4
PATR8 I know why I never have time to fix my stuff Triumph 6
JPSmit I've never seen one of these for real Spridgets 5
T Never quite know what you are going to find... Triumph 14
livinginthepast BE horn never worked. Now it won't shut up Spridgets 12
G Never buy a tube of grease AGAIN!!! [well, almost] Spridgets 7
Hap Waldrop Beer run pics, better late than never :] Spridgets 6
Jer you never know... I just bought a Bug Eye ! Spridgets 21
Jer never know who you will meet at a car show... Spridgets 4
DNK It never ends. Triumph 12
glemon Never Assume [Ignition Timing] MG 1
M TR2/3/3A NEW MEMBER INTRODUCTION BETTER LATE THAN NEVER TR3 Triumph 19
Jim_Gruber Never overlook the simple stuff Spridgets 1
JPSmit It never rains, it pours Other British Cars 12
T Never seen one of these.... MG 11
C Better LATE than NEVER! Triumph 18
PHerder Never know what you will find in the trans tunnel! Spridgets 14
S Here's a TR variant most have probably never seen Triumph 7
