mysterious leaking of SU HD8
billca
The rear SU HD 8 on my Series 1.5 E-Type is leaking through the jet when the fuel pump is on. A stream of gasoline about three inches high comes from the jet when the needle/piston/chamber is removed. The other 2 carbs do not leak and the fuel level in them is correct. Most of the typical culprits have been checked: float level correct, float needle/seat replaced, float is correct weight and has no leak when placed in hot water, jet/diaphragm replaced, float bowl overflow pipe is clear (no leaking through the overflow), float needle lever pivot adjusted, many expletives directed at the problem area.
Recently I let the pump continue and the stream of gasoline stopped after about 10 seconds during which about a half cup of gasoline came out through the jet of the rear carb and none through the other two. The gasoline level in the jet is now about 1/16 inch below the bridge in all three carburetors. I have no idea why it stopped leaking. I assume the float bowl is full and the needle is closed. What I don't know is what will happen when the float chamber becomes empty after sitting several weeks. For example, it may put another half cup of gasoline through the rear carb before closing the needle; this is a bit too rich for a typical cold start!
Does anyone have suggestions for what might be the problem?
Thanks for your ideas.
billca
Your float valve is stuck, try opening the float bowl lid and cleaning it and see if that fixes this issue.
I'd like to think you are correct; however, I've cleaned the bowl, replaced the float valve, and reset the float a couple of times (It's now at 1/2" instead of the recommended 7/16".) The float/needle mechanism works smoothly when removed from the carb. I've also tapped on the float bowl lid with a hammer with no results. What is unknown is why the float valve is still sticking and why all the gasoline is going through the jet and none through the overflow pipe.
Thanks for your response,
billca
It needs to vent so that the float will rise and close the needle and seat. Once you remove it completely and run mechanics wire up the inside of it from the end to unplug the rust and crap , your worries will be over!
Thanks for the advice about the overflow tube. I have checked by blowing through it which confirms that it is not totally blocked. However, it may still be partially blocked so that it doesn't vent fast enough. I'll run a wire through it. Wish me luck.
Billca
For the overflow, make sure you have the two washers, one on either side where the float bowl nut passes through it, in the correct locations. The "segmented" one goes on the bottom and the full one on top. If you have a full diameter washer on the bottom then gas cannot flow to the overflow pipe so it won't matter of it is free or plugged. As for why you're getting the flow, I agree with the others that the float valve is hanging up.
Just had the same exact problem with an XK 120 that I revived . Had plenty of hung up float valves but never one that caused fuel to shoot out the jets.
Conclusion: I ran a stranded wire entirely through the overflow pipe both from the top and from the bottom. In neither case did I observe any gunk come out on the wire. However, this did fix the problem. The float bowl fills, the float valve stops the flow when the bowl is full, and no fuel comes out the jet. (That was a good suggestion about the segmented washer on the overflow fitting. I did have the segmented washer in the proper place.)
Lesson learned: My original test of the overflow pipe was to blow through it with my mouth from the banjo fitting end at the top. No blockage was observed, but there must have been a partial blockage. On reflection, I recall that when the bowl was filled from being completely empty, a 3 inch high stream of fuel came from the jet. When I tested it again after a few minutes, the stream of fuel was only about an inch high above the bridge. I didn't recognize that this might have indicated a partial blockage that I missed when blowing through the pipe.
Now my only problem is that all of the 'new' fiber gaskets on all three fuel inlet banjo fittings slowly leak. Fuel seeps through the gasket material as if the material is old and dry and porous. At least I can see the problem and have ordered some more gaskets.
Thanks for all of your suggestions.
Billca
K TR2/3/3A Mysterious knocking? Triumph 9
Sopwith_Camel MGB the mysterious disapearing spark MG 21
P TR6 Mysterious rubber hose Triumph 2
bighealeysource Mysterious grinding [ouch] noise on BN2 Austin Healey 7
bthompson Sudden and mysterious death. Lucas again? Spridgets 19
M Mysterious hole in transmission Triumph 52
Jim_Gruber Mysterious Coolant Loss - Kim could this be yours Spridgets 2
D Mysterious clutch fluid loss Triumph 9
Z Mysterious poor running problem Triumph 4
ronzet Mysterious vacuum ports on intake BN4 Austin Healey 18
A TR4/4A Mysterious TR4A tranny noise [that vanished] -help Triumph 7
ObiRichKanobi Mysterious Ignition? Problem Triumph 19
B Fuel pump and mysterious cannister MG 10
B the mysterious e-type ingnition light Jaguar 9
B the mysterious e-type ingnition light Jaguar 0
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
