TR2/3/3A Mild street cam and Idle?
karls59tr
Bronze
Anyone running a mild street cam and find they have to set the idle at 1200 rpm to avoid a some what irregular idle or is it just my car?
martx-5
I've got a pretty lumpy cam (282°) and have to keep the idle at about 1000-1100 rpm.
JerryVV
I run a Kastner D Cam (284 duration) with a milled head and 87mm pistons. I can idle once engine is warmed up at 1000rpm but only after I had the carb bodies sleeved to avoid air leaks and installed a Pertronics in the dizzy. The Pertronics did the most for an improved idle. I'm running about 30 degrees advance as well.
JVV
TR3driver
Great Pumpkin - R.I.P
My previous TR3 wouldn't idle below 1200 even with a stock cam!
:D
TomMull
:D
Did you have to use the clutch and drive train to shut it off? Mine would run on terribly at anything over 900. (Perhaps that's why the manual gives instructions for ed-carbonizing?)
Tom
TR3driver
It did have a tendency to run on sometimes. I just got in the habit of always letting the clutch out right after I turned off the switch (with my foot firmly on the brake). With a little practice, I got to where it was so smooth that I didn't know if it would have run on or not.
That engine definitely had issues. It was supposed to just be a temporary solution while I rebuilt another engine to go in, but somehow the rebuild never happened. And the "junkyard dog" was still getting.me to work and back every day when the car got totalled.
K
karls59tr
Bronze
Tom
I shut the TR3 off the same way Randall describes. It runs great otherwise so I don't want to mess with it. One day I do need to have the SU bodies rebored for shaft inserts...maybe that's part of the issue of a higher idle along with a non stock cam?
TR3driver
Could be, but 'performance' camshaft grinds almost always compromise idle quality. Optimizing the needle profile to match the cam can help, some, but higher idle rpm is usually necessary.
I don't know, but I suspect that modifying the timing curve for more advance at idle would help, too. I believe the stock curve is deliberately late at idle (eg 4 BTDC instead of 10 or 12), to help prevent kickback while hand cranking.
CJD
I doknow. If it runs on with no ignition...then one would think it could idle slower with the ignition on...right?
All those idling 1k and above...it's important to realize you are operating outside the idle circuit for the stock H6's. That could be compounding the idle issues if you don't mod the carb to take it into account. We used to drill the butterflies to let in the extra air so the butterfly would drop back to its intended idle position. Then it may take drilling the mixture passage for increased idle fuel.
JerryVV
Explain please as I've never heard of this for SU's and what mixture passage are you referring to? The Jet if drilled would provide additional gas flow across the full range of the needle I would think. Maybe changing the needle to one with more flow at idle would work. I don't know what other passages could be drilled.
tinman58
My idle is at 1100 rpm's. 287 duration 89mm pistons and a lite flywheel. There is a noticeable
lump at idle. I kinda like the sound when driving thru a parking lot nice and slow. Even the Mopar Guys like the sound.
JFS
Bronze
Des Hammill states the following as reasonable idle rpms in his book on Weber and Dellorto carbs: (He states that this info is appropriate regardless of carburetaion.)
Standard cams about 240 degrees duration and 30 degree overlap, 500 rpm; Mid performance cams about 265 - 270 degrees duration 50 degrees overlap, 800 rpm; medium performance cams about 270 - 290 degrees duration 70 degrees overlap, 1000 rpm; Racing cam 290 - 320 degrees duration 70 degrees overlap, 1200 rpm. He also states that modified engines require a considerable amount of spark advance, 16 - 18 degrees @ 1200 rpm.
I run a TR3 with 280 duration 70 overlap cam and high ratio roller rockers which give a mathematical lift of .427"lift @ valves. It has twin Weber DCOEs, milled head, and Mallory dual point ignition. It requires 32 degrees total advance and at least 16 degrees to idle at 900 - 1100 rpm. The car shakes a little at idle and will not run decently with less advance. It seldom runs on when switched off. I have run this set up for a good 20+ years.
K TR2/3/3A TR3...Mild street cam....valve gap? Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
steveg Denis Welch mild cam Austin Healey 9
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
S Mild 'groaning' on clutch depression... Austin Healey 10
M Healey 3000 Mild Steel Exhaust good price Source Austin Healey 2
D T-Series Query: what's the best clutch kit - mild race? MG 9
Y Random Orbital Snader for Mild Restoration Stuff Restoration & Tools 11
K TR2/3/3A Using header wrap on a street car? Triumph 5
Basil Across the Street Spotted 2
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
K TR2/3/3A Street cam again and Valve gap? Triumph 6
Gliderman8 Falcon on street in Boston Spotted 11
Boink It's probably noisy on the street... Rover / Land Rover 0
BoyRacer Best street tires for early 3000? Austin Healey 21
S Best air cleaners/ filters for street Spridgets 8
H best street pads Austin Healey 6
G More low end and milage street 1500 Spridgets 11
B TR2/3/3A Street Roll Bar for TR3 Triumph 12
nissanite TR4/4A TR-4A FI street engine on the dyno at JB Racing. Triumph 36
Russ Austin Ballet in the street, what a treat! Triumph 7
aeronca65t Street Legal! Other Cars 8
Jer Google Street View Spridgets 7
M 1275 street peformer, any hot rodders Spridgets 21
TR3driver TR4/4A New "hot" street cam for TR2-4A Triumph 8
1 07 Triumph Daytona 675 converted to Street Triple British Motorbikes 5
L Street Tire size for 60 spoke wheels Austin Healey 15
Team_Sprite A happy little street car pops up again Spridgets 5
aeronca65t Street Racing-Poland Racing 2
Jayrz Auto-X/ Vintage race/ spirited street ride height? Spridgets 14
kcbugeye1275 Street bugeyes on Ebay Spridgets 3
T Crypt Car dies in street Triumph 17
G Street tires for the Midget Spridgets 17
D Racing equipment helpful on street cars? Racing 10
S TR2/3/3A TR3 on the street for the first time in 10 years Triumph 9
DonPete3 Street Legal? Spridgets 2
Simon TR4a MGB MGB on my street MG 12
M TR4/4A Ebay TR4 spotted by chance on the street! Triumph 0
aeronca65t Rare Costin street coupe Other British Cars 5
Y Street names Sunbeam (Rootes) 2
C Reasonable power out of a good street B motor? MG 15
S Why is this car not street legal ? Lotus 3
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
