Midget 1275 comp.
gregsdrums
Ran a compression check on the cylinders today and didn't care for the results. 120 120 85 115. No choice now but to remove the head and see what I can find. Bent valve, pushrod, broken spring, ring, or bad head gasket? This may turn in to a complete overhaul... God I love these little british cars!
Well, to quote Meatloat (adjusted): "three out of four ain't bad."
Seriously: borrow or rent a leak down tester and give it a shot. Not critical, but it might be able to tell you if it's rings or valves, which means pulling a head vs. an engine.
Touch wood, it'll be an exhaust valve - but I also believe in the tooth fairy.
Doug
:lol: :iagree:
Leak-down will tell more than a compression test does. Before you do any tear-down, perhaps giving it a water ingestion could clean up any detritus the valve seats may have collected... Worth a shot, IMO.
Spray bottle of water, rev the thing up to 2.5~3K and spray into carb pie-hole. Keep it revved and running! Oh, and do this well outdoors and downwind of anyone who'd be frightened by a LOT of white vapor clouds. :wink:
After that, a comp and leak test. :thumbsup:
Well, the tooth fairy came last nite and removed the cyl head. To my eye (that of a self-professed sledge hammer mechanic)all looks good. Head gasket, springs, valves, but there was quite a carbon build up. Chipped some off a valve, looked like about 1/8" thick. Seats looked ok but I realize the tolerances are crucial. Tops of pistons and cylinders also look good. Hope the tooth fairy comes back tonite and does a leak down test...
O.K, while the head's off, put some rings and bearings in it. Lap the valves to make sure they're o.k and put it back together. You should have had the fairy do the test first. You already got it down, go ahead and put some new parts in it.
While I'm not a big fan of hone-in-car ring jobs, it was/is standard proceedure at evey Saturn dealership. Just make sure to rinse it well w/ hot soapy water.
If cylinder walls look really good and not worn bad, might want to consider doing the head instead of a lap job.
recordsj said:
what is the purpose of spraying water into the carb and keeping the engine revd?
It cleans a lot of the deposits off the piston tops and valves/seats by burning it off.
how does the water clean the deposits off?
I see you say it burns it off, but how is it different than fuel going to the cylinder?
Magic? Voodoo?
:jester:
...my understanding is the water gets absorbed into the "coke" surface, then upon combustion the 2.5K°F flash front instantly boils the water, breaks up and burns off the detritus it has been soaked into as a result...
Internal steam cleaning of a sort.
All I know is: It WORKS. As long as you don't allow the engine to STALL in the process.
You can also reprofile SU or Zed-S carb needles with #600 wet-or-dry and an electric drill, set points gap with paper matches, adjust under-steer with an ignition key, stop a heater core from leaking with a pair of spark plugs... but I digress. :smirk:
Shhhh Doc, them is old timer secrets....
Ooops. My bad.
...I guess uses fer th' Weasel Pee is okay to divulge tho?
:devilgrin:
Youse guys quit giving away the 'secrets', please.
If you ever have just one cylinder that is pulling in coolant, that will be the cylinder that is very clean. The water acts as a cleaning agent!
Scott in CA.
D MG Midget 1275 rear oil seal. Spridgets 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
jmayzer 1275 Midget Bentley Shop Manual Download Spridgets 1
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
M Wiper motor connector removal - 1275 Midget Spridgets 4
F MG Midget 1275 oil leak Spridgets 7
R 1275 midget equivalent replacement radiator Spridgets 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
K 1275 Midget motor/trans into a 75 Spitfire? Spridgets 3
G 72 Midget 1275 Spridgets 3
G 72 midget 1275 intake manifold Spridgets 1
lbc_newbie 1275 Midget, Sprite Timing Tape Kit Spridgets 2
NardisCNC 1275 for 66 Midget - Which one?? Spridgets 3
Steve P. 1275 in a later [1500] Midget? Spridgets 1
jbowlby Roller release bearing for 1275 Midget Spridgets 20
B 1275 exhaust on MKI Midget [1098] Spridgets 3
dingleberry3343 74 midget 1275 oil galley plug Spridgets 6
Thor Putting in 1275 motor into 1500 Midget Spridgets 4
S T-Series MG Midget 1275 Reverse Light Switch - Help Needed MG 1
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
nathandarby67 WANTED: S.U. HS2 Dashpots [Midget 1275] MG 3
R Midget Mark III clutch push rod lengths Spridgets 0
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 45
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 11
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
