Miata seats and a rollbar?
t_bush
Has anyone put Miata seats in a spitfire and also fitted a roll bar? I am wondering if the head rests will clear the bar and if the bottoms will clear the bar fittings where they meet the floor.
This is the type of bar that still clears the rag top and hard top.
Thanks.
Hi the roll bar i used on my 72 spit is a tight fit the top just rubs it when putting it up or down the seats i used also just fit with no room to slide foward or back the cross bar on the floor stoped that and to recline the seat the head rest dose rub the rollbar; but you have plenty of legroom and the seat just feel so much better then the spitfire seats ; just take your time play with the seat rail a you could make it work better then i did ; good luck.
Thanks Gents. I will give it a Go.
Now I just have to find some of the seats in my area.
-Tim
Keep checking CL. Took 2 weeks to get mine
I got my seats from a local wrecking yard. I used www.car-parts.com to search the wrecking yards. They fit in my wedge with the roll bar, but I wedges have more room around the seats.
Thanks for the tip Philman.
The seats do not show up on Craigslist very often up here in the northern middle coast. I guess Miata's weren't thought to be good winter cars :square:
I was in Tulsa, OK the last two weeks and the seach shows there were a pair about 5 miles from where I was staying :wall:
- Tim
2 people are parting out cars in Minn./St Paul. see if the seats are gone.
Well after $130, four hours of driving, half a tank of gas, a trip to a less than desirable section of St. Paul and dealing with a junk yard dude high on something, Spitty has a set of Miata seats.
Black and in very good shape with just a little fading. I cleaned the heck out of them with Totally Awesome, laundy detergent and a pressure washer.
They will fit with the roll bar I have. When pushed all the way back the head rests hit the bar when reclined. I think it will be fine. I will not finish the mounting until I get the pedals in. A six foot or taller guy may have an issue. I also need to see how much clearance I have with the steering wheel. Mine is a little reward than stock.
The seats look great in the car and are very comfortable. I cut in half some foam water noodle and slipped it under the back for added lumbar support.
Thanks for the help guys.
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
F TR6 miata seats Triumph 12
Raymond MGB Miata seats? MG 1
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
M MGB MX5/Miata seats for MGBGT MG 2
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
T TR2/3/3A Will Miata seats fit in a TR3A? Triumph 7
G MGB Miata seats MG 4
Brosky Wedge Miata seats now in TR8 Triumph 8
Darrell_Walker Wedge Miata seats in a TR8 Triumph 45
CZ_Dave MGB Miata Seats in a MGB? MG 10
RickB Need info about Miata seats in Spridget Spridgets 49
DNK Miata Seats Triumph 16
Brosky Miata seats 98% INSTALLED! Triumph 16
19_again Miata or other seats in a '67B MG 5
T Miata seats Triumph 9
ChrisS Anyone looking for Miata seats? Spridgets 2
Paulus Seat adapter plates for Miata seats. Triumph 10
B Miata seats Triumph 18
D Miata Seats Spridgets 14
6 TR4/4A Miata seats in a TR4? Triumph 12
Earl TR2/3/3A Miata Seats for a TR3 Triumph 13
D Miata MX-5 racing seats Spridgets 3
D Miata seats Spridgets 4
t8nwa Spitfire FYI - Miata seats in a Spitfire 1500 Triumph 5
C Miata Seats in 1500 Spridgets 10
C Miata Seats Spridgets 1
Y Miata seats Triumph 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
waltesefalcon Miata windows Other Cars 4
waltesefalcon NA Miata gauges Other Cars 16
waltesefalcon The Miata rides again Other Cars 11
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
AngliaGT "Nice Miata!" Other Cars 13
AngliaGT Miata - ALMOST Made it Home Other Cars 7
TRMark TR4/4A Miata Battery Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
JPSmit Miata Coupe Other Cars 3
C A better sound for a Miata? Other Cars 0
R TR2/3/3A Miata Engine and transmission Triumph 12
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
NutmegCT MGA MGA/Miata MG 12
G 1994 MX5 Miata Other Cars 6
jhorton3 Replacecment Miata Seat Covers Spridgets 12
BobbyD Miata Seat Brackets..... a new approach Triumph 0
