Miata seats
donandmax
Subject: 1979 MG Midget
I have ordered a pair of Miata MX-5 seats to fit the 79 Midget. Is this a PITA job ? Or is it pretty much of a drop in. On another forum the poster said the rails fit almost exactly with just a little work from a file to get the holes to line up. What yall think.
Don M
Jim_Gruber
Don,
Been gathering info on this subject myself. Hope this helps. At the bottom of this post is a link to pics of a '79 currently up for sdale with Miata Seats installed NFI of course, included here for reference purposes. Here are responses from two folks who have gone the Miata Setas in s Spridget route. General consensus watch where you drill the mounting holes. Gas and brake lines are under there.
My question to Neil this Spridget Owner
Can I get some more info on using the Miata Seats.
1) Comfort vs. Spridget Seats?
2) LegRoom vs. Spridget Seats?
3) Seat Frame Rails, did you redrill holes or modify to fit existing Seat Frames Mounting Points?
4) My Roll Bar pushes against headrest on my '68 Spridget. Look like you've got lots more recline available vs. standard seats wit hbig fat Spridget Headrest. Not sure how rollbar will affect as Miata Seats appear thinner than Spridget Seats especially in the headrest area. Also narrower at the top so the will not be banging against the side of the rollbar.
5) $120 is just about the going price on Miata Seats in OH as well.
6) Fabric Insert, definitely cooler than the faux vinyl on standard seat.
7) I have a tonneau cover off of a '69 that used similiar pointy headrests. Hoping that this Tonneau will fit with Miata Seats ok. My other tonneau off of a '68 headrest pocket is not near as big.
8) Speakers in headrests. Do they work well? Present setup is a set of 6 x 9's in rear deck and little tweeters up front from Radio Shack simply used to load speaker outputs on CD player. Cranking up load enough to hear at speed = distortion big time. Curious on headrest speaker quality.
Response
Way more comfortable, increased leg room, nice adjustment.
Came with rails, so drilled the floor to match.
Tonneau should fit, but i don't have one to try.
Speakers in headrest are nice and can handle high power.
(Note:Headrests have zippers on side and speakers can be installed)
I did mine based on the classic article, very pleased.
I'll see what I have for pics, but do not have any of mounting brackets. Thye were easy to fit, but watch where you drill on pass side, fuel / brake lines may be in teh way!
Good luck
Neil
Similar responses from David Lieb of Chicago
1) You said you did not like the Miata Seats in your car and went
back to
> Spridget Seats. Why, oh why?
My Midget seats are pretty well worn and I am almost sitting on the floor pans. I actually like that. The Miata seats raised me enough that the top of the windshield was in my way. I was also a little less than comfortable with
the seat angle, but I did not figure out exactly why. Also be aware that the brace across the floor behind your heels restricts the motion of the seat and the adjuster. Somehow I just didn't have the "part of the car" feeling that I love about my Midget. Of course I don't get that in the Miata, either, so it could be the seats ;-) Or me.
> 2) Sticky pleather seats on Bugsy are extremely uncomfortable and even though seat bladder and lower cushion have been replaced not exactly comfortable for any type of long term driving. Cloth seats can sort of breathe I would think.
Trish loves the cloth seats in her Miata. I prefer leather, but it is her car. For that matter, I would love to rip out the sun visors on her Miata, too. At least you do not have Bugeye seats which get uncomfortable by the time you are out of the driveway. You are right, the cloth seats do not
stick to you. You can also buy seat heaters for them ;-)
> 3) Bugsy has a rollbar installed. Right now headrest bumps against rollbar and I've lost some recline in the seat back. Miata seats seem to be narrower in the headrest portion and I think I can get additional recline back to make seats more comfortable once again. Any comment?
I had not yet installed a rollbar when I had the Miata seats in the car. I agree that the bar compromises seat position and I frequently wish it was not there. I do not know how the Miata seats will interact with the bar, but
it is possible that the thinner seats in the newer (2000+) Miatas might fit better.
> Also have windblocker installed that bolts to top of rollbar and back > sides on rollbar so it sits on an angle. Does not appear this would interfere with Miata Seats.
I have the windblocker that attaches to replacement brackets by the hinges for the top bows. I have removed it because it really didn't do anything for me.
> 4) I've got a tonneau from a '69 Spridget that used the pointy headrests. Doesn't really fit my headrests so I bought another that fits properly. Think condom post coitus and that is how the '69 tonneau fit the headrests. I'm thinking that this just might be the ticket with the more
pointy Miata Seats.
My Miata seats fit my stock 1972 tonneau cover. Sometimes I had to adjust the seat-back position to line them up. I now use one of the gray cockpit covers and my tonneau sits in a corner of the garage.
> 5) Frame Rails, drilled new holes or fabricate a bracket?
I drilled new holes in the floor. A bracket would simply exacerbate the issue of seat height. I think that it would be easier to cut off the locating spikes on the bottom of the Miata rails next time rather than try to drill six precise holes per seat. Beware of brake lines, fuel lines,
and emissions return lines before drilling!!! The Midget seat holes ALMOST line up...
David
Another Note: Need to install Pass Side seats on Drivers Side so seatback recline lever in in the center same as Spridgets do now.
Pics of Spridget with Miata Seats installed
https://sandiego.craigslist.org/car/410815983.html
bugimike
Another alternative to consider that I have found satisfactory are these seats from a Corvette. I do not know the year they are from as they were given to me, but they are a drop-in fit (I did have to drill 2 holes per seat to get everything attached) with plenty of room, fit the standard head-rest pockets in a late-model Sprite tonneau cover and have the cloth inserts which are perfect in the Fl. heat! I mounted them without slide-rails as I am the only driver and placed them to my liking (which is as low as possible and as aft aspossible!), but it would be a simple matter to adapt the Spridget seat rails to the bottom of the Vette seats (there would be approx. 5-6" fore and aft adjustment possible!) The seat backs release to drop forward with a button in the back of the seat.
scott421
Member
I have these MX5 seats in my TR6 . I fabricated brackets so as to use the MX5 runners but do not need to drill the floor . The speakers work well , even at speed . the seats are far better for both comfort and support . I am looking for another pair just not to fit to my wifes Midget which I am starting to respray now.
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
F TR6 miata seats Triumph 12
Raymond MGB Miata seats? MG 1
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
M MGB MX5/Miata seats for MGBGT MG 2
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
T TR2/3/3A Will Miata seats fit in a TR3A? Triumph 7
G MGB Miata seats MG 4
Brosky Wedge Miata seats now in TR8 Triumph 8
Darrell_Walker Wedge Miata seats in a TR8 Triumph 45
CZ_Dave MGB Miata Seats in a MGB? MG 10
RickB Need info about Miata seats in Spridget Spridgets 49
t_bush Miata seats and a rollbar? Triumph 9
DNK Miata Seats Triumph 16
Brosky Miata seats 98% INSTALLED! Triumph 16
19_again Miata or other seats in a '67B MG 5
T Miata seats Triumph 9
ChrisS Anyone looking for Miata seats? Spridgets 2
Paulus Seat adapter plates for Miata seats. Triumph 10
B Miata seats Triumph 18
D Miata Seats Spridgets 14
6 TR4/4A Miata seats in a TR4? Triumph 12
Earl TR2/3/3A Miata Seats for a TR3 Triumph 13
D Miata MX-5 racing seats Spridgets 3
t8nwa Spitfire FYI - Miata seats in a Spitfire 1500 Triumph 5
C Miata Seats in 1500 Spridgets 10
C Miata Seats Spridgets 1
Y Miata seats Triumph 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
waltesefalcon Miata windows Other Cars 4
waltesefalcon NA Miata gauges Other Cars 16
waltesefalcon The Miata rides again Other Cars 11
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
AngliaGT "Nice Miata!" Other Cars 13
AngliaGT Miata - ALMOST Made it Home Other Cars 7
TRMark TR4/4A Miata Battery Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
JPSmit Miata Coupe Other Cars 3
C A better sound for a Miata? Other Cars 0
R TR2/3/3A Miata Engine and transmission Triumph 12
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
NutmegCT MGA MGA/Miata MG 12
G 1994 MX5 Miata Other Cars 6
jhorton3 Replacecment Miata Seat Covers Spridgets 12
BobbyD Miata Seat Brackets..... a new approach Triumph 0
