MGB MGB Front lights
Lynn Kirkpatrick
I have a '68 MGB GT. When I flip the headlight switch to the middle position I get tail lights and license plate lights, but no front "running" or park lights. The park lights come on when I flip the switch to the headlight position.
Is that normal, or do I have a wiring bodge?
Thanks.
Deleted member 8987
Bodge. Taillights, license and park all come from the same place, red wires, off pin 7 of the h/l switch. Your fronts are on 8. 8 should be blue. Might be an in-line connected wrong.
https://www.advanceautowire.com/
C MGB-GT MGB-GT Front Ride Height MG 0
P MGB 1974 MGB front spring length. MG 0
G MGB '71 MGB Front End Rebuild MG 2
H MGB MGB [Racing] Front hubs WTD MG 1
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
M MGB Front MGB Chrome Bump crossmember MG 3
don62 MGB mgb 76 uneven front end MG 1
Foghat73 MGB Spring compressor for MGB front suspension MG 45
RickB MGB MGB front fender alignment question MG 6
B MGB MGB front crank seal size? MG 6
D MGB MGB Front Crossmember Removal MG 15
bcliff MGB MGB Front park/signal light question MG 3
rick_ingram MGB NOS Front Rubber Bumper - MGB MG 0
O MGB-GT MGB/GT Front Sway Bar Torque Setting MG 20
kbash MGB Wanted: used MGB LE front spoiler MG 63
mgbmedic MGB-GT MGB vs. MGB/GT front fenders MG 2
beachbumbarry MGB 72 MGB front hub MG 1
EMGEBE MGB MGB Front suspension upgrades????? MG 6
Bret MGB Poll: MGB Front Spoiler? MG 24
B MGB MGB Front Fenders MG 3
S MGB Left Front Fender needed for '75 MGB MG 0
aeronca65t MGB Front-Drive MGB MG 6
M MGB-GT front GT anti-sway bar on an MGB MG 15
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
