mazda MX5 / Miata gear stick relocation
mezy
As some of you may know iI am currently rebuilding a Panther Lima, and modifying it as I go.
I thought this modification to the MX5 gearbox deserved its own thread as i can find nothing anywhere about moving the gear stick further
back on a 5 speed apart from makeng a dog leg stick, this was not an option as i want to make a centre console from dash to tunel.
So I had to come up with a way of doing this.
first off I made a template of the top of the gearbox where the shifter tower fits. I included an extension to the back edge
Then i cut two a plates out of 1/4" steel, one with the extension on the front edge
these were then welded together on top of each other.
I then welded an extension to the selector rod, made a cover for where the gear stick tower bolted on and a a top hat for the gear stick locate into.
All the modded parts ready for install
new seal inside the gearbox and one at the back where the blanking plug was
refitted the longer selector rod, reverse gear lock out and gear selector butterfly
original cover on the reverse gear lock out
then the extension plate with a selector shaft support on it was fitted
Followed by the new cover plate i made and the gear stick tower
then the gearstick,
This works just as good as Mazda intended, nice short throws. moved the stick back around 5 1/2 inches
and is now in line with the steering wheel.
amazing work, thanks for sharing!
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
rjc157 TR6 Mazda seats Triumph 3
Steve P. Formula Mazda open wheel race car Racing 0
mcmillal TR4/4A Mazda Wheels Triumph 5
3798j Mazda's New MX5RF Other Cars 2
D Mazda 3 vs Ford Focus Other Cars 5
JPSmit Tonight's question -Mazda misfire Other Cars 2
AngliaGT Mazda RX3 Wagon Spotted 0
Sherlock 2001/03 Mazda 3 Other Cars 8
JPSmit Mazda 5 bearing question Other Cars 1
JPSmit Mazda 6 question Other Cars 9
NutmegCT Mazda Protege loses high end power Other Cars 5
JPSmit Mazda 6 tires Other Cars 3
John_Mc Mazda Stereo woes... Other Cars 2
S Mazda RX8 Seats Triumph 16
Steve P. Formula Mazda Race cars; anyone know about these? Other Cars 2
NutmegCT Mazda fun - CV joint? Other Cars 6
K MGB 1970 MGB w Mazda Rotary done right! MG 13
R6MGS Europa with Mazda Rotary engine Lotus 69
Dave Russell Battery Experiment - Mazda/Healey Austin Healey 5
S mazda engine swap MG 5
Simon TR4a New Mazda MX3 Other Cars 4
G mazda 3 2005 accessorized[new] OR 2006 basic[new]? Other Cars 2
Basil Mazda RX-8 Other Cars 11
M MGB MX5/Miata seats for MGBGT MG 2
G 1994 MX5 Miata Other Cars 6
69MGC MX5 engine in B MG 24
TR3driver Miata/MX5 Steering wheel repair Other Cars 7
AngliaGT '97 Miata - Need to Replace the EGR valve - recommendations? Other Cars 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
waltesefalcon Miata windows Other Cars 4
waltesefalcon NA Miata gauges Other Cars 16
waltesefalcon The Miata rides again Other Cars 11
AngliaGT "Nice Miata!" Other Cars 13
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
F TR6 miata seats Triumph 12
AngliaGT Miata - ALMOST Made it Home Other Cars 7
TRMark TR4/4A Miata Battery Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
Raymond MGB Miata seats? MG 1
JPSmit Miata Coupe Other Cars 3
C A better sound for a Miata? Other Cars 0
R TR2/3/3A Miata Engine and transmission Triumph 12
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
T TR2/3/3A Will Miata seats fit in a TR3A? Triumph 7
