bugedd
I am assuming my master is failing. When holding the brake the pedal sinks further and further. Given I know its been bled properly, and there are no leaks, then I must have brake fluid bypassing in the master. If thats the case, am I better off rebuilding it, or replacing it? It's a disc brake master as well, and last I checked, they were hard to come by in that bore. thanks!
