I disconnected the master cylinder from the frame on my TD. The pistons in the master cylinder are frozen completely. There is a short plunger rod connected to the pedal at one end. The other end goes into the master cylinder but I can't force it out. Is it connected to the master cylinder piston in any way? /ubbthreads/images/graemlins/cheers.gif
Thank you sooo much
Thank you sooo much
