Lower Radiator Hose Connection
Dave Richards
Is there an easy way to get to the lower clamp on a BJ8?
Dave Russell
Yoda - R.I.P
If it's anything like my BN2, nearly impossible from the top. Still difficult from the bottom with a ratcheting right angle screw driver. If you get it lose, turn it to a position which "might" be easier to get to next time.
Dave Richards
Dave Richards
Thanks Dave! Not good news, but I'll pick up a ratcheting screwdriver.
I do them from the top with a long screwdriver (drier that way too).
Undo the four (4) bolts into the bottom of the radiator (not the through bolts into the chassis) and just loosen the two (2) bolts at the top to swing the bottom out enough to access the clamp.
Taking it apart always depends how the last guy put it together, but that's the way I do them.
fwtexasbj8
If you are not worried about originality and can get yours off, you can replace the lower hose clamp with one that has a hex head on it. I use an impact wrench with VERY low air pressure to be sure I do not over-tighten it. The impact wrench makes the job real simple since I do not have to have any clearance fto rotate the socket.
zblu
Yups!, sometimes you have to wonder how the previous installer of the clamp achieved such! (Was the name jesus, so as to manage such a miracle?) :smile:
AUSMHLY
Hi Dave,
Maybe it's just like real-estate. Location location location.
The clamp I use on mine has a hex nut with a flat head screwdriver slot. I positioned bolt head facing down at an angle towards the radiator release valve. I now have an easy access point with a screwdriver, or a 1/4" diameter socket extention shaft and socket. It's a straight shot.
Happy motoring!
Roger
Dave Richards
Dave Richards
Thanks Roger, you can bet that's how it's going back on!
edkap2002 TR6 lower radiator hose fitting Triumph 2
wangdango BJ8 lower radiator hose! Austin Healey 2
bobh Lower Radiator Hose Failure Triumph 6
John Turney Lower Radiator Hose Austin Healey 4
AUSMHLY Lower radiator hose Austin Healey 6
wangdango XKE series 1 lower radiator pipe size? Jaguar 1
Monark192 Radiator lower air duct panel for 74.5 B MG 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
C TR6 Lower A-arms Triumph 8
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
aero3113 100 lower windshield seal Austin Healey 4
RCarr BN1 Lower Control Arms Austin Healey 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
Rut TR4/4A Lower crash pad Triumph 9
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
M TR4/4A Left lower dash crash pad. Triumph 5
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
M TR4/4A Lower crash pads for dash....help. Triumph 4
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
