TR2/3/3A Leaking O.D. section of Transmission
Redoakboo
I am finishing the restoration of a 1954 TR-2 long Door. I have the engine running, haven't got the slave cylinder set yet, so can't get it in gear. I have been working with some of the Brit members in a effort to sort this problem.
But, the transmission only has 27k miles so I am assuming the inners are O.K. My problem is the O.D. section of the transmission leaks bad. I have replaced the gasket on the brass plug and new O rings on the lever shaft, little help. It is coming out all of the gaskets. No shop help is available in Orlando so I thought I would try and tackle the gasket replacement my self . I do have the Laycock overhaul manual, and have watched several U-Tube videos.
Any hints before I undertake this gasket replacement would be greatly appreciated. Maybe any videos you might have? Dick
If it is leaking in this area the adaptor plate is probable distorted. If the 2 long studs are used to pull the OD on to the gearbox it is easy to distort the adaptor plate.
Getting the splines in the OD section aligned with ehe gearbox shaft can be difficult and you have to hold the oil pump plunger down so the pump cam can pass over the roller.
David
All as David says.
and it’s not a case of doing up the bolts you can see outside.
the bolts securing the plate to the gearbox it within the od assembly.
you MUST remove the bolts securing the od THEN EQUALLY release the tension on the long studs. There are 8 springs under compression in there.
Thanks, I found the u-tube that includes your attachments. As the leaks are only in the OD section, looks like it going to make my job alot easier.
Dick
I would not take anything for granted, like the internals being good because of the mileage. As a minimum, replace the input seal, output seal, counter-shaft bearings, all gaskets, and synchro rings. I recommend using permatex 51813 on all contacts for the overdrive, including the gasketed surfaces. As always, here is one of my "how to" threads. The OD will be towards the end:
Dick
But they are linked as far as the oil is concerned.
you need to seal both sides of the plate - after ensuring that it is flat and straight.
elin yakov rusty beauties on YouTube have done a rebuild it’s worth looking at.
Be careful with the bolts and studs - it’s only aluminium and you can strip the threads.
When I tore down my OD transmission, there was a rather thick, soft gasket between the adapter plate and transmission. The new one, in the gasket set, was a useless thin paper gasket. Similarly, the gaskets for the brass plug were rather hard and didn't conform well to their mating surfaces. I used those gaskets, although with plenty of sealer. Still, I got some leaks; three guesses where they were.
If I were to do this again, I'd get some thick, soft gasket material and make my own. I suspect that better gaskets and sensibly used sealer would solve the problem.
When I fixed my OD leak I used the gaskets that I got from Rimmer as patterns and cut new ones from Karropak gasket material 0.025" thick. The gaskets from Rimmer had a couple of extra holes in them.
When I checked the adaptor plate it has a 0.015" distortion around the holes that the long bolts go through. The sealant pattern indicated the OD pulled up tight at those bolts and the top bolts but not across the bottom edge of the adaptor plate to OD.
Used a thin film of Permatex Anaerobic gasket maker 51813 on both sides of both gaskets. I spread the gasket maker with an acid brush to get a very thin coating on the gasket.
David
In the last image you can see a void in the sealant. There is a similar void across the bottom edge of the adaptor plate.
I did use a new plate from Rimmer.
David
Steve, when you tore down the OD section, is that the only area you replaced the gaskets? The U-Tube illustrates the procedure, which doesn't appear that difficult. Did you just open the OD section, with the 8 springs, and just replace the gaskets ? Do you have the P/N for the adapter plate? I have purchased many parts from Rimmer. /
I have made the adapter plate&accumulator gaskets from Victor Reinz gasket material. It feels soft and flexible. Also, use a Hylomar type sealer from Permatex (I don't recall the number.
Berry
Berry
I have several tubes of the Hylomar sealer. Do you have the P/N for the adapter plate?
Dick
It was one of the items I picked up when the shop that I worked at downsize. They threw in (not literally) a height gauge free.
David
very nice. Starting out with accurate measuring equipment only leads to accurate measurements and fewer surprises during assembly. Frank
Awesome...I have been using an old granite countertop, but a nice granite flat reference is high on my list!
I need to only replace the O rings on either end of the rod going through the OD section on my TR-2. The manual has a good pic of replacing the O ring under the lever side. But, nothing showing replacing the one under the solenoid cover? The seems are O.K. it is only leaking out bof neither end of this rod. Dick
Seems that there is a seal behind the setting lever on the passenger side of the OD that is held in place with a roll pin. You may be able t replace that.
The one on the solenoid side you just have to remove the plate and replace the "O" ring.
David
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
M TR2/3/3A Head gasket leaking in two places Triumph 13
Boggsy64 MGB Stormberg leaking like a sieve MG 4
