TR2/3/3A latest with my H6Ss
TexasKnucklehead
Today I thought I was going to have to reconsider using H6S's on my TR3. I thought I had an issue worked out. The rear carb bowl fouls on the firewall pass through for the heater hose. Some time ago, I made a pass through with a 90 degree bend and thought that would fix my issue. When I went to put the rear carb on today, it could not fit on the 4 bolts, because the firewall pass through was in the way. Removing the pass through is easy enough (assuming it has not been connected to the system and not full of water) but re-installing with the carb there is not so easy. The inside screw is so close to the bowl, that not even a screw driver bit will fit in there. I'll have to use a bolt, with a nut on the inside of the firewall.
But, for now it looks as I'm making progress again. The linkage is all connected, adjusted and working smoothly from the pedal. ...a few more wires, a steering column, trafficator, windshield, interior (etc) and I'll be on the road.
tinman58
Your bowls are on the wrong side. They should be to the right, standing at the right front wheel.
TR4nut
With the center pull arrangement the rear carb has the bowl towards the bulkhead unfortunately.
Jerry- I'm in a similar situation and noticed the same thing. I bought a right angle fitting from Aircraft Spruce which lets me screw down the plate first, then install the carbs, then add the bulkhead fitting as a last step. But its very very tight. In my case since I haven't cleaned up a heater yet and I'm building more of a modified driver I'm leaning strongly to blanking the bulkhead fittings and forgetting about the heater for a while.
T
TexasKnucklehead
Randy,
That crossed my mind more than once. But I think one of the coolest things under the hood of a TR3 is that green heater valve. Unfortunately, keeping the valve also forces the use of that extension tube with 2 or 3 threads into that valve. A length of heater hose running from the extension to the other side was problematic as well. It seemed all I had to do was bump the hose, and the extension to valve was leaking. My length of hose will be inside the car, because I don't have time right now to get the heater straightened out. I want to get the wiring under the dash sorted out before I add the hose.
T
TexasKnucklehead
Interesting. Is there an advantage to these carbs with the opposite side bowls?
Good question and I hope some day I'll have an answer to it. Let me start with 'I don't think there is a significant performance difference between the TR3 and TR4'. You probably know the TR3 and TR4 used the same block, but slightly larger pistons/liners. The cam, distributor and carbs also changed. The carbs changed from H6 to H6S; the S for short. The intake became longer so the carb body became not as deep and not as tall. Supposedly this was to 'breath better'. I have a TR4 cam, distributor and larger pistons/liners, but the real reason I went with the H6S, is because when I brought my TR3 home, the carbs looked like this:
(for some reason I can't add a picture right now... but you may have already seen it, the one full of sand with the metal detoriated so much the piston, or anything else does not move)
and I thought they needed more than a rebuild kit could handle. After a few months, some rebuilt H6Ss and an intake came up on ebay and I went ahead and got them for a reasonable price. Was it worth the effort? We will see. Randy and I are racing to be the first in the club to have a set, and I'm sure we will be competing on a track every chance we get.
CJD
Sounds like fun! You are moving into the phase of the restoration where it finally starts to move fast. You could be racing by spring!
TR3driver
Great Pumpkin - R.I.P
You guys got me wondering, so I checked. I have both an original TR4A setup hanging on the wall, and a brand new pair of HS6 carbs still in the box (sold as being suitable for TR4A). In both cases, the rear bowl is mounted to the front of the carb.
Don't recall where I got this photo, but it shows the bowl arrangement.
TR3driver
Just for clarity, the HS6 was only fitted to late TR4A. Early TR4 still used H6, then they changed to using ZS carbs and continued through initial TR4A production. The TR4 used the same 301466 camshaft as TR2-3A; the camshaft change was at the introduction of the TR4A.
Darrell_Walker
Hi Randall,
I don't think that is correct, or I'm misunderstanding you. The float bowls on the HS6 on a TR4A are mounted with the bowl on the front carb forward, the rear carb back. The fuel line that connects the two carbs is a large C-shaped piece, that goes around the air cleaners.
-Darrell
TR4A_IRS
Hi Randall,
-Darrell
Agree with Darrell here. My 4A has HS6 carbs and they are configured as Darrell describes.
HerronScott
Ditto on my 2 late TR4A's that came with HS6's.
Picture of the one that's still in original condition. :smile:
TR3driver
Hi Randall,
Ok, I'll check again when I get home. Maybe the ones on the wall are assembled backwards, and I didn't look carefully enough at the ones in the box.
T
TexasKnucklehead
Well, in any case, I used #10x1/2" SS allen head (3/4" will not fit in from the front) and allows enough thread on the inside for a nyloc nut and washer. The allen wrench barely fits but this is something I don't plan to be removing often.
When I got the carbs, the seller told me they were not from a Triumph, and that he had some with the rear carb bowl on the front -if it turned out I needed that. At the time I thought I was good to go... and I still do. But apparently they come both ways.
So did the TR4a have better performance? Hp? Torque? Gas mileage? There must be some reason for the change. -Still, it doesn't matter, that's what I have, and as long as I can use them, I will.
mt10flyer
I just ran out and took this pic. Both bowls facing forward, 1959 TR3. And don't make fun of my engine...it's a daily driver. :playful:
Darrell_Walker
Your engine bay looks fine! But those are not HS6s.
-Darrell
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
K TR2/3/3A The latest "It's always something." Triumph 8
vette Latest Moss Motors Magazine Austin Healey 1
drooartz The latest tool addition to the shop Restoration & Tools 25
C TR6 Latest TR6 updates and pics Triumph 10
Gliderman8 "Latest Resources" FORUM Navigation Questions 2
Boink Sir Paul's latest video... with Frogeye! Spridgets 6
Rut Latest fluid recommendations Spridgets 5
K TR2/3/3A Tyre question, and an Latest Triumph 9
PeterK General TR Nice TR6 on Griot's Garage latest catalog Triumph 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
D Lilly Engine Latest Austin Healey 14
D Lilly Engine Latest / couple of questions Austin Healey 34
Rhodyspit75 Bugeye restoration Latest Spridgets 16
Michael Oritt Randy Forbes Latest Austin Healey 11
69MGC Latest Jaguar Digital Illustration Jaguar 0
D Latest on Lilly Austin Healey 3
D Lilly Latest Austin Healey 1
G TR4/4A Latest and greatest for water pumps Triumph 18
T TR2/3/3A Alternator failure Latest Triumph 17
PC latest tool score Restoration & Tools 4
simon1966 BN1 restoration Latest Austin Healey 2
Boink Nice Bugeye spread in the latest issue... Spridgets 4
CJD TR2/3/3A Latest Tires Triumph 38
Keoke Latest Upgrade Austin Healey 3
davidb Latest - AH 3000 steering box lubrication Austin Healey 4
davidb Latest - upholstery glue Austin Healey 14
Rut Bugeye Latest Spridgets 10
C TR6 Just an Latest Triumph 1
Got_All_4 General TR What to do in a "a" type Latest Triumph 9
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
P TR6 Latest compression test Triumph 11
K 9 year Latest Austin Healey 5
Keith_M Bugeye bodywork Latest Spridgets 2
PC latest tool hunt Restoration & Tools 15
J TR2/3/3A 59 TR3A Latest Video #2 Triumph 3
Kirk_Fisher TR4/4A Flood restoration Latest Triumph 1
me61ic 1963 BJ7 Resto Latest Austin Healey 2
Boink Healey appears in latest JibJab year summary... Austin Healey 1
B Resto Latest Austin Healey 35
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
U Spitfire Questions About My Latest Spitifre Triumph 14
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
Mickey Richaud Off Topic One of Our Own in Latest Moss Mag... Triumph 9
A clutch Latest Triumph 0
P valve job Latest Triumph 9
bcliff T-Series TF Victor Latest MG 11
F TR4/4A TR4 Downdraft install Latest... Triumph 0
F TR4/4A Clitty Clack Latest on my TR4.... Triumph 5
M latest 6 pack!! Triumph 0
