Clitty Clack up-date on my TR4....
Well finally had some time this morning to get up under the TR4 and give it a good lube. However, upon inspection, the upper ball joints are busted and for some reason, I couldn't get any grease into the lower fittings (there are three towards the bottom right behind the rotor). Also, it looks like the front shocks are original? Good news, the rears were converted to shocks already. So figure an overhaul is in order. Also, the PO rigged the hub bolts with JBWELD on the front? Had one break loose taking the rim off. it was a PITA to get a wrench on it through the back with the wheel on, so I'm guessing probably rebuilt front hubs while I'm at it. Question on the hubs, I've got period correct minilights - 4 x 4.5" spacing on the lugs. Is this "standard" for a TR4 or is it "rigged" for a reason? He had hub centric rings behind the rims as well.
Any good kits out there with everything I'll need for the front end? Suggestions for upgrades? Thinking about upgrading to adjustable shocks all the way around. Why someone spent the time to take the car off frame and not replace the front suspension bits, I have no idea.
