Latest - AH 3000 steering box lubrication
davidb
up-date - AH 3000 steering box lubrication
Just a quick update on my leaking steering box, which was in fact leaking quite badly, and after having tried a number of lubricants. The John Deere Corn Head grease works well, and is designed specifically for this type of application, for the most part on farm vehicle steering boxes. One of my local countrymen, Healey Nut, suggested this and so with nothing to lose I bought a couple of tubes, popped one in the grease gun and filled the box up, taking care to move the steering wheel back and forth to ensure that the grease was loading well. It took the better part of one standard tube, and the results thus far have been very good. No leaks to speak of. My understanding is that the corn head grease doesn't "mix" well if your box still has oil in it.
Anyhow, just passing along my experience. Was not looking forward to taking that grille out again....
DB
Healey Nut
Re: up-date - AH 3000 steering box lubrication
DB
Glad it worked out . Corn head grease is the way to go in our steering boxes .
4tecdog
Some vintage steering box lube good too, found my steering box and idler nearly dry over a year ago not leaked a drop since filling with Penrite s/box lube.
bob hughes
I'll go with the Penrite too. Did the job on my box 3 years ago and apart from the column/box connection 'working' and grease can be seen at the joint-- can't figure that out, I have no problems with it, certainly not at the bottom any way.
:cheers:
Bob
blueskies
The corn head grease is strange stuff - not liquid and not solid, but some of each. The main problem with it has to do with getting enough of it into the steering box. I used a grease gun and one of those pointy needle attachments on the grease gun. Moving the steering wheel back and forth helped the grease to settle, allowing for adding more grease. It also likely would be a good idea to check the grease level after some use.
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
K TR2/3/3A The latest "It's always something." Triumph 8
vette Latest Moss Motors Magazine Austin Healey 1
drooartz The latest tool addition to the shop Restoration & Tools 25
C TR6 Latest TR6 updates and pics Triumph 10
Gliderman8 "Latest Resources" FORUM Navigation Questions 2
Boink Sir Paul's latest video... with Frogeye! Spridgets 6
Rut Latest fluid recommendations Spridgets 5
K TR2/3/3A Tyre question, and an Latest Triumph 9
PeterK General TR Nice TR6 on Griot's Garage latest catalog Triumph 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
D Lilly Engine Latest Austin Healey 14
D Lilly Engine Latest / couple of questions Austin Healey 34
Rhodyspit75 Bugeye restoration Latest Spridgets 16
Michael Oritt Randy Forbes Latest Austin Healey 11
69MGC Latest Jaguar Digital Illustration Jaguar 0
D Latest on Lilly Austin Healey 3
D Lilly Latest Austin Healey 1
G TR4/4A Latest and greatest for water pumps Triumph 18
T TR2/3/3A Alternator failure Latest Triumph 17
PC latest tool score Restoration & Tools 4
simon1966 BN1 restoration Latest Austin Healey 2
Boink Nice Bugeye spread in the latest issue... Spridgets 4
CJD TR2/3/3A Latest Tires Triumph 38
Keoke Latest Upgrade Austin Healey 3
davidb Latest - upholstery glue Austin Healey 14
Rut Bugeye Latest Spridgets 10
C TR6 Just an Latest Triumph 1
Got_All_4 General TR What to do in a "a" type Latest Triumph 9
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
P TR6 Latest compression test Triumph 11
K 9 year Latest Austin Healey 5
Keith_M Bugeye bodywork Latest Spridgets 2
PC latest tool hunt Restoration & Tools 15
J TR2/3/3A 59 TR3A Latest Video #2 Triumph 3
Kirk_Fisher TR4/4A Flood restoration Latest Triumph 1
me61ic 1963 BJ7 Resto Latest Austin Healey 2
Boink Healey appears in latest JibJab year summary... Austin Healey 1
B Resto Latest Austin Healey 35
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
U Spitfire Questions About My Latest Spitifre Triumph 14
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
T TR2/3/3A latest with my H6Ss Triumph 22
Mickey Richaud Off Topic One of Our Own in Latest Moss Mag... Triumph 9
A clutch Latest Triumph 0
P valve job Latest Triumph 9
bcliff T-Series TF Victor Latest MG 11
F TR4/4A TR4 Downdraft install Latest... Triumph 0
F TR4/4A Clitty Clack Latest on my TR4.... Triumph 5
M latest 6 pack!! Triumph 0
