Slight Vauxhall Latest - and a question
JPSmit
Slight Vauxhall up-date - and a question
I haven't been posting too much about the Vauxhall, but, I know this crowd like shiny things. You may recall the engine was seized before I got it. More precisely, there were two engines, one good one - stripped and "pickled" and another spare, seized. Guess which one they left and which they brought with them? So, thirty thou overbore later and new pistons courtesy of ebay and we are good to go. Then I found out that swapping the new pistons to the existing gudgeon pins was really not a DIY job, so, off to the engine shop we went and, an hour later we were good to go. So, without further ado:
before:
and now:
Oh, and, the distributer, two actually, went off to be rebuilt and re-curved this week at Advanced Distributer - I am excited about this and, realized today that the pistons came from the UK, this week I sold parts to the UK and Austria, I am getting advice from New Zealand and all the corners of this board and of course the shop and the car are in Toronto - got to love the Interweb!
Hope to start building this weekend
JPSmit
JPSmit
Re: Slight Vauxhall up-date - and a question
Oops and the question. The original engine had a rope rear seal - I have a rubber replacement (it is an effective conversion) what should I glue it in with?
aeronca65t
Congrats on the gudgeon pin installation! (how often do you get to say that?)
I can't be sure of how your Vaux seal is set up, but Hylomar is almost always a good choice.
https://www.hylomarsealant.com/
waltesefalcon
The conversion should be good. There is a reason no one uses rope seals in engines any longer. I'm with Nial though a little Hylomar is never a bad idea.
JPSmit
JPSmit
Quick question. Is there a permatex alternative to Hylomar? They don't seem to carry it here. (Rant: I went to a parts shop instead of Canadian Tire - as I wanted knowledge and not a part time teenager. Went to the oldest guy there and he was still clueless! - arrrggghhh!!! I guess you pay peanuts, you get monkeys - that said I walked out. I don't reward ignorance any more)
JPSmit
JPSmit
Got a line on Hylomar - some guy named Tony, says he'll meet me out back and that he only carries the best offshore Hylomar - OK I made that up, but, apparently Mark saw some recently - and is looking on my behalf. I on the other hand ended up with a touch of the flu, so, not much getting done anyways. :(
Answerman
Hey John-Peter... completely off topic but every time I see you post I get reminded that I want to bring this up. Did you take your avatar picture yourself? If so, I submit that you have visited Elkhart Lake, Wisconsin, perhaps to visit Road America?
I recognize a Wisconsin county road sign when I see it (we seem to be fairly unique in that we use letters instead of numbers for county roads) and I live about an hour from Elkhart Lake. And I believe that's the only County Road JP in the state.
Platinum
Hylomar ~is~ a Permatex product, JP. If you come up empty-handed WRT the Hylomar, Nial's suggestion of the #2 Permatex would be a good "fall-back."
I've found the elusive goo sporadically, if I see it in a parts store I buy it. Harbor Freight down here has stocked it in the past. Haven't checked them in a while tho.
JPSmit
JPSmit
Well spotted, indeed it is. I was there in 2011 for the 50th anniversary of the square bodied Spridgets - got to meet a few from the boards. These were my other pictures worth keeping
and
JPSmit
JPSmit
Yesterday I reassembled the crankshaft - quick question - The crank seems very tight in place - how easily should it move?
waltesefalcon
It shouldn't be too tight. Did you plasti-gauge it? And if so what was the clearance?
JPSmit
JPSmit
.002. tolerance is .001 - .0032
Platinum
And is it "tight" thru 360° or only in one area of rotation?
JPSmit
JPSmit
at this point it isn't budging at all - at least not by hand. Heading out of town tomorrow so maybe will get back to it sunday pm. The last bearings have "sides" for the thrust - and it seems like that might be where it is binding.
JPSmit
JPSmit
Well, nothing like being away for a day or two to help you think. Decided to loosen up the bolts and start over. Loose it rotated, torqued the centre bolts to 40lbs, it rotated, tightened next set - it rotated, basically torqued and rotated one set at a time, and, it turns fairly easily now - certainly by hand with not a ton of effort. Thanks for advice.
Bayless
The only resistance you should feel is the inertial mass of the crank. Any friction probably suggests a problem. Hope that made sense.
JPSmit
JPSmit
it does, i think i am getting some friction, partially from the rear rubber seal and partially from the thrust bearing. The fifth bearing has kind of an upsidedown "u" shape to it, with the sides being the thrust part of the thrust bearing and it seems they are just a little snug, which I think is a good thing at least initially
Bayless
There might be a very little resistance from a new seal even if well lubricated. I think the thrust bearing though would be like the mains, really no resistance other than the lube. I really think I would want to open it back up and look for any problems especially since you said it tightened up after the last main was torqued. Better that than destroy it first time you fire it up. I don't remember all that you have done but it could be wrong bearings or maybe needs to be line bored. When I had the Prefect motor rebuilt several years ago, I had to replace one main cap which required line boring. The shop bored to the wrong diameter and had to change to other bearings, Taunus of some sort.
JPSmit
JPSmit
Good thoughts. I think I will get a second set of eyes when I get back.
K TR2/3/3A Slight surging at Idle? Triumph 11
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
S TR2/3/3A Slight clunk in the rear assembly somewhere. Triumph 3
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
Martinld123 A slight hesitation stumble at speed Austin Healey 13
busybrit MGB Slight starter motor noise MG 5
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
JPSmit Slight rant Other British Cars 9
V 1275 slight miss, what's the cause??? Spridgets 20
Anthony_S TR2/3/3A TR3a slight shake at 60-65 mph Triumph 8
M Slight bind in front brakes Spridgets 7
bigjones Slight timing problem Spridgets 3
longbridgehealey very slight miss Austin Healey 3
T GT6 slight vibration in GT6, with power Triumph 4
bigjones HS4 - 1500 - slight problem Spridgets 24
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
bigjones Slight wheel alignment problem Triumph 9
JPSmit slight rant - solenoid Spridgets 3
J Spitfire Slight intermitant 78 Spitfire Triumph 14
kodanja Slight changes Triumph 16
Woodie hs2's slight hesitation under load Spridgets 40
P Slight engine hesitation Spridgets 7
P Slight loss of brake assist until pumped once Triumph 4
Sherlock Suggestion for "slight" name change Rover / Land Rover 1
S slight clicking/tapping noise after a head rebuild Spridgets 4
Basil Slight problem with rear hubs [EType] Jaguar 7
W Military Discounts for Vauxhall Vehicles? Other Cars 3
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
JPSmit Back to the Vauxhall Other British Cars 9
JPSmit Vauxhall question - I know, weird eh?! Lotus 6
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
JPSmit Ain't it always the way [Vauxhall though] Spridgets 9
JPSmit Tonight's new skill - re-keying locks. [Vauxhall] Restoration & Tools 1
L Vauxhall Cresta and Velox Other British Cars 0
BWA Viva las Vauxhall Other British Cars 4
JPSmit Vauxhall Viva Gt & Lotus 7 of sorts Spotted 3
JPSmit Vauxhall Viva [I think] Spotted 9
JPSmit Dropped off the engine for the Vauxhall last week Spotted 3
C Vauxhall Victor Other British Cars 16
JPSmit Looking at the Vauxhall tonight Other British Cars 4
aeronca65t Escort, Vauxhall.......Camaro Other British Cars 10
JPSmit Vauxhall Steering Rack Question Other British Cars 1
Sherlock 1970/73 Vauxhall Firenza [Canadian version] Spotted 6
JPSmit Vauxhall Victor Spotted 1
JPSmit Vauxhall Viva GT Other British Cars 23
JPSmit I'm thinking of a Vauxhall Viva Other British Cars 10
Mickey Richaud Vauxhall on Ebay Other British Cars 3
78Z Envoy Epic - Vauxhall Viva Other British Cars 4
JPSmit Vauxhall for sale Other British Cars 3
