MGA Larger head studs in MGA engine
Michael Oritt
Does anyone have thoughts or info on increasing the cylinder head studs from 3/8" to 7/16" on an MGA engine?
Why would you want to do that Michael?
AN bolts have a tensile strength of 13,800 lbs
Grade 8 has 16,560 lbs...
Who ya got building yer engine Michael???
[Note to self....Protest his fuel /bcforum/images/%%GRAEMLIN_URL%%/yesnod.gif ]
Note to self--FAGGEDABOUDIT!
The Twincam uses the larger studs but I can't think of ny reason of benefit from doing that to a pushrod engine.
Michael Oritt Larger head studs in MG engine Racing 14
2wrench One head stud larger than others Triumph 14
H larger flex fan Austin Healey 2
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
cbrvfr Larger carbs? Crankcase breather w/ K&N's? Austin Healey 7
drooartz MGB Stock vs larger exhaust [MGB] MG 10
PatGalvin TR2/3/3A TR3 Compression Ratio with larger bore liners? Triumph 5
MadRiver Larger tires for Original Rims? Triumph 5
PGSberg TR6 Replacing Trans Fill Plug with Hex Head - NPTF or BSPT threads Triumph 6
C MGB Storing a cylinder head MG 5
Carlbanan56 MGB MGB cylinder head MG 11
jfarris TR2/3/3A Control Head Rewire Triumph 4
K TR2/3/3A Pressure testing the radiator to find a head gasket leak? Triumph 7
K TR2/3/3A Photos of new head gasket.... Triumph 3
K TR2/3/3A One more coolant leak cylinder head question..... Triumph 5
K TR2/3/3A Cylinder head liner protrusion specification? Triumph 1
JCL TR4 TR4/4A TR4 Head Seeping Water Through Intake Casting Triumph 13
Michael Oritt Paint Aluminum Head? Austin Healey 3
K TR2/3/3A Odd cylinder head core plug (picture). Triumph 7
K TR2/3/3A Mystery object in my cylinder head water jacket ??? Triumph 14
K TR2/3/3A Cylinder head valve stems and guides.... Triumph 3
K TR2/3/3A Cylinder head anomaly.... Triumph 15
K TR2/3/3A German made head gasket from BPNW Triumph 0
K TR2/3/3A Blown head gasket Blues....probably time for a rebuild? Triumph 14
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
