Job from heck [do NOT change this to Heck!!]
G
Well guys, I got my car back, and installed a copper pipe vacuum advance (copper is pretty under a hood - prettier than straight black hose) and ADJUSTED THE SCUTTLE VENT LID so now it works!
The vent turned out to be the job from heck. Ed was right; the spring was in upside down, so it would not let the vent open more than an inch, and it would fall closed. Worthless.
The job took me 2 hours! 15 minutes to take it apart, and 1 hr 45 min. to get it reversed and back together. Even with my little hands, it was nearly impossible, as the opening was so small when hooking up the hardware. Putting it back together required holding the lifting arm with one needle-nose pliers, holding the 1/4" clevis bolt with another needle-nose, "adjusting" the height of the lid with my wrist, and pushing the clevis bolt thru the lid bracket and lifting arm when their holes lined up. I got it in on the second try, but I had to undo the two spring ends from their eyes on the lid, as I could not line up the holes with tension on the lid.
So, after getting the clevis bolt in, and a cotter pin in it, I had to fit the two spring ends back into their "eyes." With more finger strength, it might have gone better.
Regardless, it was a warm fuzzy feeling when I finished it and pulled the knob and the lid opened, then pushed the knob and the lid closed. I did NOT have to adjust the cable!!
Till it oxidizes and turns green. Better clear coat that sucker.
(Im guessing the title was changed?)
Well at least it is done George. Should last another 30 years, so the 2 hours is amortized over a long time at least.
To quote Cosmo Castorini from the movie "Moonstruck"--
"Look, there are three kinds of pipe. There's the kind of pipe you have, which is garbage, and you can see where that's gotten you. Then there's bronze, which is very good unless something goes wrong, and something ALWAYS goes wrong. And then there's copper, which is the only pipe I use. It costs money. It costs money because it SAVES money!"
For what it's worth....
Editor_Reid Job Production Cards Austin Healey 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
JPSmit todays's job - and a question Spridgets 25
Busted knuckles TR2/3/3A A job for a rainy afternoon, Triumph 2
John Turney No Job is Really Simple Austin Healey 17
M Next job[s] on Otto - thoughts? Spridgets 35
R Paint job Austin Healey 6
B TR6 Paint Job Needed Triumph 9
Jim_Gruber I think I know why the rear brakes weren't exactly doing their job. Spridgets 9
CessnaTPA Paint Job Cost Austin Healey 32
P TR6 Grease job Triumph 6
D Head job Spridgets 13
TulsaFred Bugeye garage paint job - start to finish [almost] with lessons along the way Spridgets 28
alanjohnturner TR6 for those planning a new paint job Triumph 3
B Midget Paint Job Spridgets 12
sim In progress 58 paint job by Premire body and paint in Visalia Ca Restoration & Tools 0
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
alanjohnturner TR4/4A door handles - nice Winter job Triumph 1
Boggsy64 MGB Paint job MG 26
bigjones Front brake job - any advice? Spridgets 94
Willie_P TR4/4A PAINT JOB/BODY WORK - quote help Triumph 15
D Valve job Triumph 2
P Follow up to valve job Triumph 3
D Almost ready to start roller paint job Spridgets 4
P valve job Latest Triumph 9
jlaird Looking for a zinc plater for a small job Spridgets 11
M can't complete my brake job! Austin Healey 15
RickB "Finished" my rattle can paint job Spridgets 19
S 6 degrees of separation - job needed Spridgets 0
Bob Claffie Big job ahead MG 10
1 T-Series Parts I'll need for clutch job? MG 16
M brake job on '63 BJ7 Austin Healey 16
Jim_Newman grease job.......? Austin Healey 7
Morris I hate my job... Spridgets 22
T What is your least favorite related job? Triumph 43
mountainman TR2/3/3A TR3 Picts of Paint Job Triumph 15
hondo402000 TR6 TR6 Paint Job Finale Triumph 14
T Post-War Other No such thing as a 1 hour job on a Herald Triumph 8
bighealeysource sanding and buffing of paint job Restoration & Tools 12
hondo402000 TR6 TR6 Paint job nearing completion Triumph 19
B Video link of the last paint job Restoration & Tools 12
hondo402000 The Paint job continues Triumph 2
hondo402000 TR6 TR6 Paint Job Continues Triumph 11
T Worst TR job that turned out not to be a big deal Triumph 20
bighealeysource What to do with old paint job that is cracking Restoration & Tools 6
Tabcon My first head job! Triumph 19
D my new paint job Triumph 11
C 1500 Head Job Spridgets 15
JPSmit 88 cent job tonight Spridgets 4
