Worst TR job that turned out not to be a big deal
tdskip
So what was your biggest mental block that had you dragging your feet on a "big/nasty/ugly" sort of repair issue that turned out to be no big deal once you actually started doing it?
TR6oldtimer
Everything, because it means commitment.
Don Elliott
It's not the worst. That one hasn't happeded yet !
But two days ago, my overdrive just stopped. I would flip the switch and there was no click and the O/D would not work. It had been working a few minutes earlier. I was about 5 miles from home after a 120 miles trip in the sunshine for a picnic with Louise.
When I got home, I lifted the floor carpet on my side, re-connected the wire which comes down behind the brake and gas pedals and - as we say here in French Canada - "voila".
How did I know what to check first ? Well it's happened before - it's called experience. The more you drive these cars and work on them, they become more reliable and if something does occur, it's not the end of the road - or your life. Just make good your brakes are good and you will never have a really SERIOUS problem. And make sure your handbrake works. There is always a second "back-up" for you to get home again.
TR3driver
Great Pumpkin - R.I.P
I solved that problem long ago, by re-routing those wires through the engine compartment.
Forgot all about it, until I moved the OD to the 'project' TR3 a few weeks ago. Now the wires run through a grommet in the firewall, and there is a plain plug in the hole in the tunnel.
TR3driver
That would be the steering box rebuild on TS39781LO. I put that off for many years because I thought it would be such a bear; but it turned out easy. And the benefits (of that and the steering/suspension rebuild at the same time) were huge!
Oh yeah, changing the fan bushings on TS13571L turned out easier than I expected, too. Except for knocking over the recently painted front apron, and putting some big gouges in the paint!
G
Here is where I will have you all beaten! You do NOT want to get into any "Gordon Badwrench" contests with ME!
My horns have not worked since I got my car last month. Just a quiet "purr" out of the right one. The previous-previous owner had done all the work on the car. Since it involved rack and pinion steering, new wiring had to be installed for the horns.
The PO said that I needed to straighten out the ground.
You could hear my car groan, "Oh $hit, here he comes and he's got his TOOLS."
Anyway, I know that the system has been changed to negative ground. I cannot tell which wire off the horn is ground or live, as one goes up the steering column and one disappears into the harness. So, I got out my jumper cables to see if the horns work if wired straight to the battery. I cut out a solder splice on two wires, stripped them, and twisted them together. I GUESSED that they were the ground. I hooked up the positive jumper cable to the other solder splice (three wires), then lightly tapped the ground cable against my new splice. No sparks, so I hooked on the cable and hit the horn button. Voila! So, the horns work. I took the ground cable off the battery and touched it to a screw on the dash and the horns worked.
Now it gets interesting. I attached a new ground wire to the screw on the firewall, twisted it around my twist splice, and put a twister cap over the splice. Then removed the jumper cables. I hit the horn button. THERE HAS NOT BEEN SMOKE LIKE THIS SINCE THE CHICAGO FIRE!
I figured "no way" did I attach my ground wire to the wrong splice. So, I removed it, and just TOUCHED it to the other splice and the horns sounded! Without the horn button being pressed!
So, Gordon has struck again. WITH ONLY TWO WIRES, he has the option of an engine fire or a permanent horn blaring. At this stage, the fire seemed the preferable of the two, as it would not disturb the neighbors.
So, I said the heck with it, and unhooked my new ground wire from the splice, and put the screw cap back on the splice. Remember, I have not touched the other splice. After all is said and done, I get in and try the horn button. The horns are loud and clear.
I have no @#$%^&*&^%$#@#$%^&* idea why they work. The only change has been that I replaced a solder with a screw cap.
And, of course, the Zen question of the day, is WHY WHEN I HOOK ANOTHER GROUND WIRE TO THE GROUND SPLICE DOES A FIRE BEGIN?
Now, who here wants to contest me? Warning, I will next hit you with my breaking the heater core out of my 2-week old new Miata while installing a $2 Prestone Radiator Flush Kit: $550 - would you like my ex-wife's phone number?
TR3driver
George, TR3 horns are not "grounded". Of the two wires, one always gets power from the battery (supposedly through a fuse, but I'll bet someone has installed an American fuse instead of a Lucas fuse); and the other goes to the horn button.
The horns also do NOT care about polarity. Maybe somewhere there is a horn that does care, but I have never seen one on any car, Triumph or not.
But if it's any consolation, I also learned the hard way that heater cores won't take full garden hose pressure. Totally ruined a TR3 heater that way, at a time when new ones were simply NLA (and good used ones were unheard-of).
gubba
I'll bet someone has installed an American fuse instead of a Lucas fuse.
What does that mean please? whats the differance?
martx-5
The rating system on the fuses is different. A Lucas fuse is rated at the amperage at which it will blow, whereas the American fuse is rated at constant ampacity. What it amounts to is that to get an equivalent Lucas fuse, you need to cut the amperage rating about in half if using an American fuse. In other words, replace a 50 amp Lucas fuse with a 25 amp American fuse.
Don Elliott
George - After 47 years since you sold your black/red TR3A you are really getting back into the spirit of TR ownership super fast with the TRials and TRibulations of your "new" red TR3B. All it takes is experience and you get that by trying something. That's the way all problems in life are solved - not just TR problems.
TR3driver
Precisely.
But also note that "50 amp" fuses were only on early cars. Somewhere around 1958 or so, the horn fuse changed to a "35 amp" Lucas (which can be substituted with an AGC 20).
TR3driver
One other difference; less important but worth considering; is that the British Standard fuses are slightly smaller than the American standard ones. The TR2-4 main fuse holder will take either size, but some of the holders are more picky.
Proper size fuses can be sourced from TRF, Moss, VB, etc.
cmacmillan
None of my signal lights worked...had visions of someone finding me strangled in a mass of wires. I'd heard that sometimes the connectors just need to be cleaned but since they didn't look that dirty, I figured I had a much more serious issue, but I thought - start easy and then ramp up. 4 minutes with a wire brush and behold: signal lights. Hoping the braek lights are similarly easy!
kodanja
Over the 29+ years of working on these little British terrors, I've found theres no easy fix~!
Just plan on being prepared to do more than ya thought the job was gunna be.
"Just when ya thought you were done with one job another comes into play" :wall:
TR_JOE250
The day before yesterday I was driving my 73 Spitfire and after stomping on the gas I expierienced a sudden drop in power and the engine ran as if it was being robbed of air or fuel or both. At low throttle and RPM it was ok but once I gave it a bit more it would run poorly. My first check was the fuel filter, which I found to be quite dirty. Yeah, I thought to myself, I've found the problem. After a quick change I was off to test out my handiwork. Much to my diapointment this did not solve the problem. So with the bonnet raised I stared at the fuel pump and carbs (euro setup, twin SU's) wondering where to start I noticed that something didn't look right with one of the ait filters. After removing the cover I found that one of the mounting bolts had backed out and the air cleaner had sliped down and was cutting off airflow to the rear carb. A quick retightening of ALL related bolts and I was running fine. You have got to love it when what you thought cuold be a major problem turns out to be a quick and easy fix, and the fuel filter was way over due for a change.
John_Mc
As a first timer, I thought suspension refurbishment was going to be hard. It really wasn't. There was a lot I DID as far as cleaning and painting while I was in there, but if I did it over again just to replace worn bushings, it would be a breeze. Although with any job, there will always be one stuck bolt that will make me crazy.
jlaird The worst job so far Spridgets 5
Rob Glasgow Worst jobs on a Healey Austin Healey 31
CZ_Dave I am my own WORST enemy! MG 8
D Opinion of the Worst Cars Triumph 40
F What are some of the worst... Austin Healey 7
M worlds worst oil leak Triumph 22
AUSMHLY I am the worst driver....I get 9 mpg...help! Austin Healey 107
newmexTR3 Worst Triumph insults? Triumph 44
aeronca65t Worst Triumph Ad This Week Triumph 23
C Stag STAG -- One of the 50 Worst Cars Ever? Triumph 13
kodanja Tell your worst TR horror story! Triumph 45
T Our worst nightmare....but with a happy [?] ending Triumph 6
G Always at the worst possible time Triumph 9
D 50 worst cars of all time... Triumph 8
Russ Austin Time Magazine's "The 50 Worst Cars of All Time" Triumph 36
Bret Worst car I’ve ever driven. Other Cars 43
Nunyas I fear the worst MG 18
Bruce Bowker Perhaps the worst Sprite Spridgets 9
G World's Worst Cars.... Triumph 5
H Worst Healey Ever Austin Healey 15
Simon TR4a Another don't think the worst. Triumph 1
KLUTZ Don't always think the worst !!!! Triumph 8
t8nwa Worst thing about owning a new S British Motor Corp 15
G The best of the worst Jaguar 6
Editor_Reid Job Production Cards Austin Healey 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
JPSmit todays's job - and a question Spridgets 25
Busted knuckles TR2/3/3A A job for a rainy afternoon, Triumph 2
John Turney No Job is Really Simple Austin Healey 17
M Next job[s] on Otto - thoughts? Spridgets 35
R Paint job Austin Healey 6
B TR6 Paint Job Needed Triumph 9
Jim_Gruber I think I know why the rear brakes weren't exactly doing their job. Spridgets 9
CessnaTPA Paint Job Cost Austin Healey 32
P TR6 Grease job Triumph 6
D Head job Spridgets 13
TulsaFred Bugeye garage paint job - start to finish [almost] with lessons along the way Spridgets 28
alanjohnturner TR6 for those planning a new paint job Triumph 3
B Midget Paint Job Spridgets 12
sim In progress 58 paint job by Premire body and paint in Visalia Ca Restoration & Tools 0
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
alanjohnturner TR4/4A door handles - nice Winter job Triumph 1
Boggsy64 MGB Paint job MG 26
bigjones Front brake job - any advice? Spridgets 94
Willie_P TR4/4A PAINT JOB/BODY WORK - quote help Triumph 15
D Valve job Triumph 2
P Follow up to valve job Triumph 3
D Almost ready to start roller paint job Spridgets 4
P valve job Latest Triumph 9
