It has started
JPSmit
My official countdown to spring. Yesterday and today we had the "snowfall of the winter" (both inches) the garage is mild enough to work in and SWMBO and son are watching Lost. Time to start the list of what needs doing.
On the list.
1. get carb refurbished.
2. get overflow can repaired.
3. properly align wheels including centering steering wheel.
4. remove and check oil pan for leaks around rim.
5. change oil.
6. get wheels properly balanced.
7. figure out short in fuse #1
8. figure out why headlights go off when left turn signal is turned on. (I think it is a ground)
9. replace horns.
10.get tonneau repaired
11.finish sorting top.
12. Clean Clean Clean.
13. Drive Drive Drive.
Tonight.
1. Carb removed and ready to get repaired.
2. Overflow can removed and ready to get repaired.
3. grille off for access to horns and wiring.
4. shop a little cleaner.
Let us Pray
Dear Lord, let it warm up soon.
Please keep us from the Prince of Darkness
Amen.
drooartz
Funny how you can be heading towards Spring and we're still very much in Winter here! Good luck on your project list.
Jer
Emphasis on task 13 ;-)
G
JP, I don't know if you've ever had the front of these down but look real good at where the "wedges" go in the front rail. Dumbest design I've ever seen.
JPSmit
JPSmit
Not sure exactly where you mean but I'm guessing the bottom front of the engine. If so, yes, you're right staggeringly stupid. I think I managed to get it sealed when I put it back together but I'll look very close.
T TR6 Car has always started without fail.....until now Triumph 10
S TR2/3/3A Frustration has started but car wont. Triumph 4
drooartz MGB-GT Conversion has started - splines to studs MG 51
jaegzie Long time since I've been here but progress has started. Bigeye rebuild Spridgets 9
2wrench MY CAR HAS STARTED....PICS/VIDS NOW WHAT? Triumph 11
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
B tachometer cable has a hole in it Restoration & Tools 7
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
P Hoping someone has this measurement easily available. Austin Healey 3
E General TR Hertitage certificate: factory record has not survived Triumph 11
R General Tech Preserve eng/trans that has been removed Triumph 11
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
C TR6 A lot has happened. Update on my project Triumph 7
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
vette To Johnny who has posted an Article in the Articles Section about his German Exported Austin Healey 9
BOBBYR My Dad has to be laughing Austin Healey 4
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
steveg Steve Kingsbury has lost everything. Austin Healey 11
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
Sarastro TR4/4A Camshaft oddity has me concerned Triumph 6
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
5 For Everyone that has a BUGEYE OR FROGEYE Spridgets 3
M Overdrive has a mind of its own Austin Healey 21
Mickey Richaud Mod Note "Tinkerman" Has Passed Triumph 23
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
PeterK TR4/4A From a VTR post on Facebook. Herman has passed. Triumph 16
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
Rut The Eagle has landed! Spridgets 19
KVH General Tech New Camshaft Has Rust Triumph 7
Jim_Gruber SUCCESS- VROOM, VROOM has been heard in Beavercreek, OH this evening Spridgets 31
BJ8Healeys This one really has me stumped! Spridgets 4
Editor_Reid Roy Jackson-Moore has passed Austin Healey 1
MisterB Engine spins, has OP, but......... Austin Healey 10
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
steveg Has anyone used a knock sensor? Austin Healey 0
NutmegCT So many cars! So much has changed! Other Cars 10
simon1966 Happy New Year. 463 BEV has a lot to look forward to. Austin Healey 5
TomMull TR2/3/3A Herald has a friend, TS58023 Triumph 5
S Has it really been 3 years? Spridgets 2
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
